Author Topic: IPAC-2 Stops Working Mid-Game  (Read 2459 times)
RxBrad
  • Last login:May 31, 2023, 12:41:00 pm
  • I like burritos.
    • bit.ly/1GDVYUu
    • RxBrad.com
« on: June 29, 2017, 09:19:49 pm »
My late-2015 IPAC is acting up. After my Windows 10 PC has been running for a minute or two, it either stops responding, or gets stuck on the last button I pressed. Before I get too far into troubleshooting, I just wanted to make sure there haven't been any recent Windows updates that have commonly sabotaged other people's IPAC setups.
Note that if I unplug and replug the USB connection, it works again.. but only for about a minute.
« Last Edit: June 29, 2017, 09:24:41 pm by RxBrad »
adder
Re: IPAC-2 Stops Working Mid-Game
« Reply #1 on: June 29, 2017, 09:28:59 pm »
could you test the ipac on a different pc/laptop?
you could just plug it in via usb and then open a text editor window and use the ipac like a keyboard inputting random characters for a while and see if it locks up/loses connection etc
scottyNLG
  • Last login:December 01, 2018, 11:24:58 am
  • New Life Games slot/arcade tec
« Reply #2 on: June 29, 2017, 10:15:24 pm »
I had the same problem in the past the problem turned out to be that the connector on the ipac somehow came loose and wasn't making a good contact and sometimes shorted out and triggered false button presses the way I fixed it was to resoldering the connector back into place. hope this info helps you :)
Your friendly neighborhood arcade tec
RxBrad
  • I like burritos.
    • bit.ly/1GDVYUu
    • RxBrad.com
« Reply #3 on: June 30, 2017, 07:50:47 am »
It appears that my USB hub must've been flaking out. I waited for the controls to freeze up, then opened up the cab and noticed that the green light on the IPAC wasn't lit. Then I hooked the IPAC directly to one of the motherboard's onboard USB ports, and played for a couple hours with no problems.
