Author Topic: Arcade Buttons - How to Install  (Read 2039 times)
THRobinson
  • Last login:December 28, 2021, 05:11:31 pm
  • Early stages of my first build!
« on: May 27, 2017, 06:20:41 pm »
To stay within budget, I opted to buy a kit of the buttons and joysticks. Look good, bit 'clicky' but still should work for me.
Prob is, how do they install?
I managed to get the microswitch off, but I can't get the nut off and don't want to break anything trying the wrong way.
I assume you drill a hole the size of the threaded body, smaller than the top... put it in, slide the sleeve up from the back, then the nut, then put the guts/switch into the button, but they came preassembled and no directions.
Anyone have any experience with these?
With the microswitch out it looks like this
Self design cabinet, using a Samsung 204B 4:3 LCD, and RaspberryPi 3B+  running RetroPi.
THRobinson
Re: Arcade Buttons - How to Install
« Reply #1 on: May 27, 2017, 08:34:59 pm »
Well... took a bit of playing around, dismantled a bit more than I needed to before discovering it's 1/8th of a turn counterclockwise and pulls right out.
paigeoliver
  • Awesome face!
« Reply #2 on: May 30, 2017, 01:49:01 pm »
You will be replacing those in short order anyway, they are designed for gambling and kiosk operations where people only press a button once. They feel terrible to actually play a game on where you press a bunch of buttons.
