Author Topic: LCD Marquee Monitor  (Read 3703 times)
DrLarryE
  • Last login:January 23, 2018, 10:03:26 pm
LCD Marquee Monitor
« on: May 11, 2017, 02:05:46 pm »
I haven't yet checked into any of the programs that would be used to put the proper marquee up when playing a game, so I don't know how they detect which game is being played.  Simple question....Would any/all work with MameWah as the frontend?  (I don't know if it detects the game through MAME, the frontend, or some other way)
raph
  • Last login:May 25, 2024, 03:21:37 am
  • Gradually adding bells and whistles to a stock cab
Re: LCD Marquee Monitor
« Reply #1 on: May 11, 2017, 04:26:21 pm »
Mamehooker detects it via MAME itself.
MAME itself also has support for it if you make a layout file.
stigzler
    • Mago Arcade
« Reply #2 on: May 11, 2017, 05:27:41 pm »
If you're just using mame in your cab, I think you have lots of options. Think some others have even just used Mame itself to display the marquee file on a separate display?
If you're looking to use other systems on your cab, you'll need other options. I have separate LCD displays for marquees and controls and wrote this app to populate both:
https://sites.google.com/view/magoarcade/software/cpwizbiz
You can use scrollers, videos, flash, gifs etc on your marquee displays if you so wish (although I jst stick with images to keep it trad)
« Reply #3 on: May 12, 2017, 01:00:58 am »
Mamehooker will do mame, supermodel and mess natively.  It will also do any emulator with the game title in the window title with a bit of setup.
I've found the real problem isn't the software, but finding a suitable monitor for the marquee at a good price.
