Author Topic: Connecting old jukebox to separate amp  (Read 3513 times)
Hjm80
  • Last login:May 05, 2017, 07:25:42 am
« on: May 05, 2017, 07:25:42 am »
Hi is there a way of connecting my old nsm jukebox to a separate amp so I can play it through my stereo as well as the jukebox speakers? It's an 80's joke box that plays 45's.
Cheers
lilshawn
Re: Connecting old jukebox to separate amp
« Reply #1 on: May 05, 2017, 02:39:36 pm »
it's possible. it really depends on which system it is.
- you'd either have to tap off the needle signal directly and feed it into a phono pre-amp.
A turntable produces a PHONO output signal. This phono signal needs to be converted to a LINE LEVEL signal (sometimes referred to as AUX signal) to work with audio equipment including stereo systems, computers, and speakers. A "phono pre-amp" converts PHONO to LINE LEVEL.
OR
- if it has some kind of output on the amplifier, then you can tap off this signal and feed it into your audio equipment.
it may or may not require a pre-amp, whether it does or not depends on where/what/how it's set up.
How you go about this is going to highly depend on what jukebox it is and how the system is facilitated. if you can find out a make and model number, we might be able to get a little closer.
