Author Topic: CISCO HEAT sidear redraw for project  (Read 5829 times)
Marcoqwerty
  • Last login:January 04, 2026, 06:20:39 pm
« on: March 08, 2017, 05:23:09 am »
Hello guys
I looking for some help tips and anything else for this reastoring project, i cleaned too much the sideard of this CISCO HEAT (maybe some italian conversion of the original cabinet) with some aggressive products.
So i obtain this result....some missing and matt parts; for me hard to replace because im not a pro under illlustrator (i had redraw some marquee in the past but nothing with this complexity...
If someone could help me i will provide the hi-res photos showed below  :notworthy: :notworthy:
PS: no CISCO HEAT redraw has found online....or HIRES flyer picture....
mahuti
Re: CISCO HEAT sidear redraw for project
« Reply #1 on: March 08, 2017, 11:05:40 am »
Redrawing the star wouldn't be tough as vector art. Then you'd just need to get it printed.
As for the other art, if you wanted to get that done too, you'd need to get a very high-res photo or scan of the existing art and have someone clean it up in Photoshop. It's not vector art, so it would need custom (virtual) airbrushing to remove any scratches or marks. I do that kind of thing, but for a project this big I would have to charge for it. Most of the damage looks pretty easy to fix.  I wouldn't think it would take more than about 3 hours.
Marcoqwerty
« Reply #2 on: March 08, 2017, 11:24:41 am »
Thank you mahuti for the answer!
- the star is almost done by me...yes in the past i made for myself some easy redraw with AI...
- mmm i did a Hi-res picture of the sideard good for cleaning (3000x4000 will be enought ? ); you gave me a cool idea....not redraw but clean it with photoshop or gimp....for me will be more easy to do, im more pratic to clean picture to redraw these; but at the end the result will be the same? i mean ater print process....
Just to know....how much you take for a work like this?
« Last Edit: March 08, 2017, 11:27:10 am by Marcoqwerty »
mahuti
« Reply #3 on: March 08, 2017, 04:13:39 pm »
3000x4000 is probably close. I'm guessing that's close to 300DPI at size? If so, I would say it's good enough IF the photoshop file doesn't look like it's losing data compared to the real thing. The main issue might be dealing with stochastic dots if those were used in the original art. If it's pretty smooth and the dots are small, fixing it up in Photoshop and then having someone output should be no big deal.
As for pricing, when I do this stuff professionally, I charge a lot. Here on the arcade boards I charge a fraction, or trade if possible. Last time I did something for someone here it was about 6 hours of work and I think I ended up being paid about $20 an hour. It was pretty complicated stuff... had to airbrush out a lot of stuff. I attached a before and after just so you can see .
Marcoqwerty
« Reply #4 on: March 09, 2017, 04:04:17 am »
Yes... 3000x4000 is the file resolution and the DPI was 300; omg i didnt hear nothing about stochastic dots, i would  recolor every area of the image not only the missing parts maybe this could be enought  to print. :dunno
I i forget to say...i didn't used a professional reflex..but my old compact camera; maybe i can't get the same detail or will be the same?
mahuti
« Reply #5 on: March 09, 2017, 04:11:04 am »
Probably the biggest concern will be making sure the reproduction image matches the dimensions correctly when printed. if you took a photo, it's sure to be warped... even if only a little bit. You'll have to take good measurements of the real art, and then adjust the perspective of your photo to match the dimensions.
Marcoqwerty
« Reply #6 on: March 09, 2017, 04:30:49 am »
Really thanks for the tips..... i made the picture at 1 meter of distance perfectly parallel to sideart without flash in the daylight......
