Author Topic: Ami r84 voltage problem  (Read 3858 times)
Phill sugden
  • Last login:November 26, 2018, 05:06:32 am
« on: March 07, 2017, 10:39:56 am »
Hi
I have a ami r84 jukebox i am trying to find the correct voltage for the power supply unit
I have on mine 28vdc 28vac and 11.5 to 14. Should the 11.5 to 14 be 8vdc as on the psu
Or is this accepotable
Phill
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: Ami r84 voltage problem
« Reply #1 on: March 14, 2017, 06:22:46 am »
Hi Phil,
On the 8 Volts DC it is normally about 7.9 volts with a sall load of a test lamp on it.
If the voltage is 11.5 to 14 volts, had better get the power supply unit checked out and the CCC as well because it may have damaged components in the CCC.
Regards
Alan
Alan Hood
ami-man
UK
Phill sugden
« Reply #2 on: March 17, 2017, 12:03:26 pm »
Hi alan
Thanks for the phone chat
I have the board out it's a ami 6-08873-01 power supply board
The capacitors c502 c503 c504
Axial capacitors c501 1500uf 50 v c500 3300uf 35 v all bulging on the ends
Will change them
What value are the zener diodes cr501 & cr505
Resistors r510 & r501 I cannot see the banding colours there discoloured
Do you have the values and wattage
Are the capacitors anything special or just standard ones
Schematics diagram would be asking too much
Thanks again regards
Phill
ami-man
« Reply #3 on: March 20, 2017, 06:18:21 am »
Hi Phil,
C501 should be 1250 mfd 50 volt
CR515 is 13 volts
CR501 is 7.5 volts
R501 is 470 ohms 1/4 watt
R510 is 0.82 ohms 2 watt (wire wound)
Regards
Alan
Alan Hood
ami-man
UK
« Last Edit: March 23, 2017, 09:22:15 am by ami-man »
Phill sugden
« Reply #4 on: March 22, 2017, 02:47:20 pm »
Hi alan
Thanks for the info but the resistor I can't see is r510 not r512
Iam going to change the transistors q500 q501 & q502 is the mpsa06 an equivalent
Are the cr500 & cr506 Zener diodes & what value
The c501 1500uf looks original but I will change it
Thanks again
Phill
ami-man
« Reply #5 on: March 23, 2017, 09:27:17 am »
Hi Phil,
I have edited the above message regardin R510
CR500 & CR506 to CR514 are just silicon diodes.
Q500 to Q502 are NPN transistors
Regards
Alan
Phill sugden
« Reply #6 on: March 29, 2017, 12:57:28 pm »
Hi Alan
Changed all capasitors and all transistors voltages are back to the right voltage jukebox working great
I have Read a lot of posts and they have been a great help too
You're doing a brilliant job
Thank you for your help much appreciated
Yours phill
