Author Topic: Naomi 2 Beach Spikers 4 player  (Read 3780 times)
GreatLamer
  • Last login:July 17, 2025, 04:27:37 pm
« on: March 03, 2017, 08:26:27 am »
Hi,
Is there any way to make Demul Naomi 2 settings turn to 4 player mode? Default machine is 2 player only.
I want to play Beach Spikers with 4 player.
DarthMarino
  • Last login:December 17, 2025, 10:53:45 am
Re: Naomi 2 Beach Spikers 4 player
« Reply #1 on: March 03, 2017, 06:23:40 pm »
The Gamecube versions works great on Dolphin.  That version supports 4 players.
GreatLamer
« Reply #2 on: March 04, 2017, 11:51:36 am »
Thanks, already done. Just found the arcade version a better looking one, and gameplay is faster.
chillinwater
  • Last login:February 04, 2026, 10:32:07 pm
« Reply #3 on: March 26, 2017, 06:59:19 pm »
If you still would rather play the arcade versions, using demul, you CAN add 4 player support while in the demul front-end config|controls or by manually editing the "demul.ini" and "padDemul.ini" files inside your demul root directory.
You also need to make sure you have "padDemul.dll" in the plugins folder inside your demul directory.
You can download it here, top right is latest version.
http://demul.emulation64.com/
« Last Edit: March 26, 2017, 07:01:35 pm by chillinwater »
GreatLamer
« Reply #4 on: April 09, 2017, 05:38:03 am »
Thanks for the answer. I can't do anything with that. I really can't find any related configuration options.
MydknyteStyrm
  • Last login:March 20, 2024, 12:19:41 pm
  • Makeup FX Gamer
« Reply #5 on: June 20, 2017, 12:17:49 am »
Did you try to change the confit in game? Use the JVS test button you set in Demul. Usually I'll find changes like that in the games setup screen
Sent from my iPhone using Tapatalk Pro
