Author Topic: Rowe ami r-84 no power  (Read 2606 times)
Carlkip
  • Last login:February 25, 2017, 02:58:07 pm
« on: February 24, 2017, 10:07:25 am »
Hi I have just bought a Rowe ami r-84 jukebox it came as spares or repair I have tried putting it together as best I can it does not have any powe when I turn it on I have bought a service manual but am no electrician any advice of where to start would be appreciated many thanks carlkip
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: Rowe ami r-84 no power
« Reply #1 on: February 26, 2017, 06:27:25 am »
Hi Carlkip,
You had better check out the power supply (junction box) for any dry joints (cold joints USA) on the connection pins to the power supply PCB, check all the diodes with a diode test if your meter has one.
If the above is too much for you get your power supply checked out by a Rowe Ami service engineer.
Regards
Alan
Alan Hood
ami-man
UK
