Author Topic: How many coin start buttons should i use?  (Read 2523 times)
GroovyTuesdaY
  • Last login:June 07, 2005, 03:22:18 am
  • "Follow the white rabbit! ....KNOCK KNOCK NEO...."
« on: January 25, 2004, 02:53:37 am »
I am at a funny junction of my panel development and i need a little guidance here.
I am building a 2 player panel that has 4 joysticks and 16 buttons. The trouble i am running into is trying to figure out whethere i need to have coin button for each player or do i need just one for both?    I am wanting to use the KEYWIZ MAX, just because it has 32 inputs on it and i dont want to spend a fortune on an ipac 4 player when i dont need so many inputs.  So, in order for me to have a pause button, i am trying to see if i need to lose a coin button.  I wasn't sure how many games out there that actually need a separate coin insert for each individual player.     So if anyone out there can give me a little guidance on this one it would be MUCH apprecited hhehe.
I want to stay away from shift key type functions as it seems to always screw something up when i am in the middle of a game when i would hit certain key combos or if player one and player 2 would make some funky combo and do some strange things as well.
                  groovy~
« Last Edit: January 25, 2004, 02:56:04 am by GroovyTuesdaY »
In the mighty words of the BEE GEES im-
"STAYIN' ALIVE, STAYIN' ALIVE!"
hehehe
wpcmame
  • Last login:February 18, 2024, 01:27:00 pm
Re:How many coin start buttons should i use?
« Reply #1 on: January 25, 2004, 06:05:35 am »
There aren't many games that need more than one coin button. I only got a coin1 button and then use a shifted input as coin2. I use pause as shift button so there is no risk of hitting it during gameplay.
Tiger-Heli
    • Tiger-Heli
« Reply #2 on: January 25, 2004, 09:11:21 am »
Gauntlet definitely needed individual coin buttons if you wanted to play as the red character, etc.  I think maybe Simpsons or a few other games do as well.
Suggestions - if it's a 2-player panel, I don't know of any 2-player games that used dual joysticks and more than 2 or 3 buttons.  You might be able to map one of the joysticks to some of the action buttons and free up some inputs.
Otherwise, it is possible to program the KW MAX as follows:  Set-Shazaaam! and Player 1 button 8 to be programmed as 6 (Coin 2).  Now wire a button with diodes to activate Shazaam! and P1B8 at the same time.  This is your coin 2 button.
No shifted codes to remember, and since Shazaaam is an independent function - no chance of accidentally hitting it either.
You could use this same method for both coin and both start buttons and create 4 additional inputs.
Drawbacks to this approach -
Whenever someone presses Coin 2, for as long as the button is held down, every other button will send it's shifted rather than regular input.  (This can be minimized by programming the shifted and standard output to be the same key.)  (Of course P1B8 will insert another P2 Credit in this scenario, and if all the start and coin buttons were shifted, you might end up with lots of extra credits)
The joystick directions cannot be shifted, so the Player 1 and Player 2 characters will briefly freeze while the Coin 2 button is held down.
The P1 Left (or right?) button will swap codesets when shifted so there is a possibility of changing codesets althogether if coin 2 is pressed while the Joystick is moved Left (or right?).  This can be overcome by some clever wiring tricks.
None of these are show-stoppers, in fact I plan to use these methods on my panel.  I just wanted to point out what to expect.
See http://www.fraggersxtreme.com/arcadepanels/encoder/shiftkeys.htm for an explanation of wiring a shifted button with diodes (the "Advanced Method" on the schematic), and see http://www.fraggersxtreme.com/arcadepanels/encoder/nocodeload.htm for how to wire the KeyWiz to avoid alternate code set swapping.
If I lost you, you could E-mail RandyT and he can explain this also.
Brad Lee
  • Last login:May 26, 2005, 11:39:04 am
    • 666
« Reply #3 on: January 25, 2004, 12:43:25 pm »
Is therea 2P version of gauntlet? I know on Simpsons and some of the other 4p games like that, they had 2p versions where you could do a character select
Yeah i just did some playing, and there is a gauntlet (2 player) rom, so you would hit coin1 for the 1st players credit, and coin2 for player2. At the beginning of the game you pick your character
I would vote for 2 coin inputs
« Last Edit: January 25, 2004, 01:10:11 pm by Brad Lee »
crashwg
« Reply #4 on: January 25, 2004, 01:07:30 pm »
Gauntlet (2 Players, German, rev 1)      gaun2pg1
Gauntlet (2 Players, German, rev 4)      gaunt2pg
Gauntlet (2 Players, Japanese, rev 2)   gaun2pj2
Gauntlet (2 Players, Japanese, rev 5)   gaunt2pj
Gauntlet (2 Players, rev 3)                    gaun2pr3
Gauntlet (2 Players, rev 6)                    gaunt2p
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
Tiger-Heli
    • Tiger-Heli
« Reply #5 on: January 26, 2004, 06:34:34 am »
If I understood correctly, the question was 2 or one coin input, not 2 or 4.  So what we would need to know is if you can put 2 coins in Coin 1 and start a 2P game?
« Last Edit: January 26, 2004, 07:25:48 am by Tiger-Heli »
wpcmame
« Reply #6 on: January 26, 2004, 07:10:37 am »
Unfortunatly there are no intermediate releases of the 2 player roms. If you think the normal release is to difficult you need to use the 4 player intermediate version.
Brad Lee
    • 666
« Reply #7 on: January 26, 2004, 09:01:43 am »
Understood. For the majority of games, you can use coin1 to accumulate credits and just push Start1 or Start2 to start playing. The couple examples(gauntlet, simpsons, 4p wrestling & basketball) games NEED independent coin slots. If those are games he's interested in playing, it would be beneficial to have 2 coins instead of 1
Sephroth57
  • Poo Monkey
  • Last login:June 07, 2020, 11:17:00 am
    • Check it out!!!
« Reply #8 on: January 26, 2004, 09:02:03 am »
oh those versions are actually harder? ive been playing the 2 player one... maybe thats why i thought i sucked at gauntlet =P
"Owens is the ringleader in the ass hat circus"  D K
  • Last login:July 02, 2026, 07:26:12 pm
« Reply #9 on: January 26, 2004, 09:28:57 am »
Regarding the 4 player games.... almost all of them have special two player clones which aren't effected by which slot you put the coin in.  So unless you are building a 4 player panel this won't be an issue.
Tiger-Heli
    • Tiger-Heli
« Reply #10 on: January 26, 2004, 09:47:47 am »
Not true!  I just tried Gauntlet (2 player), (in MAME V0.70 b/c I didn't have the latest rom, but it shouldn't matter.)
While you can now select any of the four characters to play as, if you just drop coins in Slot 1 ("5 key"), you can never start a 2-player game.  Only when you drop coins in Slot1 and 2 ("5 and 6 key") can you start a 2 player game.
So at least for these few games, you do need both coin slots.
wpcmame
« Reply #11 on: January 26, 2004, 12:41:31 pm »
I thought so too. The game seemed so much harder than I remembered but then I read this faq http://db.gamefaqs.com/coinop/arcade/file/gauntlet_i_ii.txt
