Author Topic: Arcade Engineer Consultant needed - I/R Gun Solution and Driving  (Read 5527 times)
irgunhelpreq
  • Last login:February 22, 2017, 08:26:25 pm
Hi
I am looking for someone to help us build out a IR Gun solution for windows. We would like to use as much as we can that is already out there. Happ Guns? IR Sensors etc.
We are looking for someone to build out a solution (Commercial grade - arcade grade). Gun, IR, Software for Windows. (We require sensors around the screen so normal PC type units will not work)
PM me if you are interested and have the expertise and we can discuss rates etc.
Also looking for a driving solution (force feedback) wheel, motor, pedals and software ( if we can use Logitech feedback control software that would be easiest)
Regards
Sorry if i posted in the wrong area as this is my first post.
Titchgamer
Re: Arcade Engineer Consultant needed - I/R Gun Solution and Driving
« Reply #1 on: February 22, 2017, 06:18:34 am »
Ultimarc Aim Traks and Top gun already do windows compatible IR guns where you can mount tge sensors inside/behind a monitor bezel.
irgunhelpreq
« Reply #2 on: February 22, 2017, 02:05:43 pm »
Thanks for that. Aim track is great but we require something more commercial.
I need something a little more rugged than the aimtrak setup and would like to get a setup that is similar to a current arcade gun setup (none joystick).
Multiple LEDs around the screen and recoil that is commercial grade.
