Author Topic: GGG Roundhouse joystick question.  (Read 1607 times)
lowlytech
  • Last login:February 07, 2019, 08:12:12 am
« on: February 14, 2017, 09:55:06 am »
I have two of these roundhouse arcade sticks that I was going to use on my control panel.  One main question.  Does this top come off so I can undermount the joystick?  I can't seem to loosen it at all.  Thought I would ask before I broke it.  I noticed GGG didn't have a color option with this particular joystick.  Looks like the only way is to disassemble the 4 phillip screws in the base of the joystick and then try to put it back together very tediously.  If that doesn't' work out is the spitfire a good comparable joystick?
lowlytech
Re: GGG Roundhouse joystick question.
« Reply #1 on: February 14, 2017, 01:16:37 pm »
Kind of embarrassed, there was a nut on the bottom that released the joystick to allow undermouting, however try as I might, this balltop will not come off.  Was wanting a different color, but red will have to do I suppose..
« Reply #2 on: February 14, 2017, 01:36:06 pm »
You can always upgrade to a Sanwa JLF.  The ball top screws off and there are a TON of options.
