Author Topic: .  (Read 47795 times)
Re: TCA - Ghouls n' Ghosts Project cab pickup and Restoration!
« Reply #80 on: August 02, 2017, 05:23:50 pm »
Excellent.  We shoot footage for a laminate installation video. but i'm not sure sure how we're going to edit it yet.   :(
Have you guys ever used laminate on a CP and drilled through it? I have a restore where I am doing that. I am nervous to ruin the laminate I put on.
Sent from my XT1585 using Tapatalk
Did you drill the holes first and then laminate or do you need to drill a hole through both the laminate and the wood?
tebright1
  • Last login:August 27, 2020, 12:26:03 pm
« Reply #81 on: August 02, 2017, 05:48:02 pm »
Both.
« Reply #82 on: August 02, 2017, 06:23:27 pm »
I would recommend clamping a sacrificial board on top that you can drill through.  The laminate will be less likely to chip that way.  Make sure you drill down into the laminate otherwise it may try to separate from the force of the drill.
You could also make a hardboard template with your holes drilled where you want them.  Clamp the template on top of your laminate and use a pattern routing bit to route the holes.  A router bit would be less likely to chip than a drill bit.
Both.
ChanceKJ
« Reply #83 on: August 03, 2017, 03:51:35 am »
« Last Edit: March 19, 2021, 12:29:09 am by ChanceKJ »
tebright1
« Reply #84 on: August 03, 2017, 08:46:47 am »
Thanks guys! This really helps.
Sorry to steal some thunder from you thread Chance.
Keep up the good work.
« Reply #85 on: August 03, 2017, 09:24:17 am »
You need to time lapse that 12 hour video of GNG though.  Seriously.  It would be a cool montage.
DeL
That's a great idea.
I feel like that would get me a legit visit from Paul, with a gun. And he'd also try to steal my dog.
.... :P
I love that damn dog. :cheers:
