Author Topic: Missile Command trackballs  (Read 7141 times)
matsadona
« on: February 01, 2017, 03:34:20 am »
I have some questions about Missile Command trackballs. The upright cabinet had the huge 4” (4.5”?) model and according to some sources the cabaret and cocktail had the much smaller 2 ¼”. Was there any different gearing ratio or did you have to play the game differently depending of cabinet type?
Since the possibility to find a working upright MC here in Sweden (for a reasonable price) is almost below zero, I’m planning to build a MAME setup. Finding an original trackball is probably equally impossible so it will be any of the currently available 2 ¼” or 3” USB trackballs.
What experiences do you have regarding this? If you use a small trackball do you change the sensitivity settings in order to compensate the ratio difference etc?
jimmer
  • Last login:February 17, 2025, 02:48:38 pm
  • I want to play Defender like at the arcade.
Re: Missile Command trackballs
« Reply #1 on: February 01, 2017, 05:15:38 am »
google Mr Awesome Missile command conspiracy if you want to learn about trackball settings on Missile command  ;D
I will soon be making 4.5" trackballs.
« Last Edit: February 01, 2017, 05:18:12 am by jimmer »
On forums jimmer speaks for himself as a Defender fan, not as proprietor of www.jbgaming.co.uk  << Is that advertising or disclosure ? or both ?
behrmr
  • Last login:April 23, 2021, 09:17:13 am
« Reply #2 on: February 01, 2017, 02:09:29 pm »
On the game PCB there is a dip switch setting for mini or large trackball.  So if you are using a smaller than 4.5" trackball you may need to adjust the sensitivity of the trackball/mouse or in MAME set the dip switch to mini.   I think it will basically be something for you to play with to get the right feel.
cw
  • Last login:March 26, 2026, 09:24:03 pm
  • Game over man game over
    • The Cab
« Reply #3 on: February 01, 2017, 05:47:56 pm »
wow what a rabbit hole that was  ....
matsadona
« Reply #4 on: February 02, 2017, 05:23:48 am »
Sweet. Anything to share regarding that?
« Last Edit: February 02, 2017, 05:32:43 am by matsadona »
matsadona
« Reply #5 on: February 02, 2017, 05:28:53 am »
"You have to assume that Walter may be back on drugs"...  ---steaming pile of meadow muffin---, I never heard about this mess before. Thanks for noticing. Now I must view all the episodes on youtube.
« Last Edit: February 02, 2017, 05:32:56 am by matsadona »
  • Last login:May 15, 2026, 05:08:29 pm
« Reply #6 on: February 02, 2017, 01:45:22 pm »
I've e-mailed him about once every 18 months for 10 years trying to buy a copy of his book.  Have never gotten a response.
Cash on the barrel head for anyone that has a copy.
RandyT
  • Last login:June 24, 2026, 02:15:54 pm
    • GroovyGameGear.com
« Reply #7 on: February 03, 2017, 01:59:49 pm »
Based on my calculations, and a 4.5" ball (which I believe is the correct size), one would need to set the sensitivity of a 3" ball to be 1.5x (or 150%).  That is, of course, if the MAME code is correct at 100%, which I cannot confirm, when used with a trackball which uses quadrature decoding.  IIRC, a number of early Atari titles didn't, so knowing how the original handled the data from the control is an important first step in matching the actual sensitivity value.
But if the original did use full quadrature decoding, things would get a bit worse.  In this circumstance, the issue with doing things the way I described above is that, much like using a low-res spinner and increasing it's sensitivity for a game like Arkanoid, you would be upscaling and therefore lose accuracy as a result.  In other words, you can't add resolution, you can only even out the amount of movement at the control to match the same distance covered by the cursor on the screen.  However, if this turned out to be the case, you can increase the resolution of the trackball by replacing the standard encoder wheels with a higher resolution variety, and adjust the sensitivity to match what you need it to be.  It's one of the benefits of using high resolution encoders, such as the ones we offer with our trackballs.
