Author Topic: Rowe R-84 Prelude  (Read 2541 times)
mkballard77
  • Last login:January 24, 2017, 04:29:32 pm
Rowe R-84 Prelude
« on: January 22, 2017, 04:33:58 pm »
I have a Rowe R-84 Prelude Jukebox. It sounds great, but a couple selections don't play. I have records in the slots, but when I pick those, nothing happens. I can select other ones, so I'm fairly certain it isn't the buttons. Other selections will play. It just refuses to play certain slots. any ideas where to start?
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: Rowe R-84 Prelude
« Reply #1 on: January 23, 2017, 07:29:41 am »
Hi mkballard77,
Are these selections that it will not play ending with the third digit 8 or 9?
if the above is the case you may have fitted a RI-3 to RI-5 Pricing Board, check that there is not a diode in these two locations on the pricing board CR333 (160 play) and CR334 (RI-3)
Regards
Alan
Alan Hood
ami-man
UK
mkballard77
« Reply #2 on: January 24, 2017, 04:29:32 pm »
Right now, it's 108/208 & 144/244 that won't play.
ami-man
« Reply #3 on: January 25, 2017, 08:17:15 am »
Hi mkballard77,
Test the keyboard switches for continuity with a meter, check the top and bottom connections on the pricing board for dry joints (cold joints USA) on the connection pins, regard the pricing board as a glorified connector rather than a credit device because all lines of data go through this board.
Regards
Alan
Alan Hood
ami-man
UK
