Author Topic: JVL Bootup SQL error  (Read 5969 times)
ZapDOH
  • Last login:January 19, 2017, 11:37:14 pm
« on: January 19, 2017, 11:37:36 pm »
I JUST bought a JVL eclipse off Craigslist.  While checking it out prior to purchase I noticed the fan sounded rough so the first thing I did when I got home was open it up and pull the fan to clean it.  I put the fan back in and now I get this strange sql error on boot up right after it says "loading games..."
"Error:  (0) is 0!  Error "SQL logic error or missing database" while executing SQL: "UPDATE StatUsage SET Value = Value + 1, Value1 = Value1 + 1 WHERE statII = 1005"
Has anyone seen anything like this?  I tried reseating every connector that I had to take off to get the fan unmounted and haven't had any luck.
Please let me know if you need more info and thanks in advance for looking!
brtlkat
  • Last login:September 03, 2021, 08:33:36 pm
Re: JVL Bootup SQL error
« Reply #1 on: January 20, 2017, 08:07:02 am »
Did you try and reseat the cf card? May have jarred lose changing the fan.
