Author Topic: Paint cabinet before applying vinyl?  (Read 3835 times)
ginkgoblue
  • Last login:April 18, 2020, 01:49:02 pm
« on: January 12, 2017, 10:25:47 am »
Hi guys. Hopefully this is a straight forward question.
Is it's at to paint and/or prime birch plywood before applying vinyl graphics?
 Can you apply graphics direct to plywood? Or better to paint or laminate?
Build in progress
mahuti
Re: Paint cabinet before applying vinyl?
« Reply #1 on: January 12, 2017, 10:52:04 am »
If the vinyl graphics are full size, I'd prime. If they're just a small portion of the side of the cabinet, prime and paint first. Priming and/or painting will make sure that the vinyl has a very smooth and even surface with a consistent pattern that won't show through.
ginkgoblue
« Reply #2 on: January 12, 2017, 11:26:41 am »
So, would it be easier(?) to laminate it and apply artwork to the laminate? Or is primed better?
I ask because I plan to laminate all "non arted" panels....
Build in progress
mahuti
« Reply #3 on: January 12, 2017, 01:10:33 pm »
So like.. black laminated like a countertop (or similar)? Vinyl would stick just fine to the laminate I would think. As long as it's dust free and dry.
ginkgoblue
« Reply #4 on: January 12, 2017, 02:31:00 pm »
Right. Or would I just be better off priming where I plan to apply vinyl?
Build in progress
mahuti
« Reply #5 on: January 12, 2017, 04:00:27 pm »
Either seems like it should be fine. I'd just apply the laminate all over and put the vinyl over the top.
