Author Topic: [solved] GroovyArcade Linux - /dev/disk/by-label/GA not found  (Read 2991 times)
Francesco
  • Last login:April 18, 2020, 04:26:54 am
« on: December 25, 2016, 06:58:34 am »
Hello everyone,
 i have Groovy Arcade installed on a 80 GB IDE disk and it works.
Now i would like to try the same hd on another pc that is inside an already made cab, and i obtain this error when booting:
I have tried also on other pc without luck. I attach a shot.
Is there a way to solve the problem? When i move a disk with linux inside it almost always works fine even with different hardware.
I have tried modifying fstab using device names instead of labels but nothing changed.
Thank you in advance and happy christmas ;) .
« Last Edit: December 26, 2016, 03:43:56 pm by Francesco »
Francesco
Re: GroovyArcade Linux - /dev/disk/by-label/GA not found
« Reply #1 on: December 26, 2016, 03:43:33 pm »
Seems there is an error in initrd creation configuration: http://superuser.com/questions/769047/unable-to-find-root-device-on-a-fresh-archlinux-install
As it turns out, Linux could not detect any drives due to the block mkinitcpio hook (responsible for block devices) missing from the default image. This was due to it being placed after autodetect in /etc/mkinitcpio.conf. To fix this, the HOOKS=... line in that file needs to be changed so that block comes before autodetect
Before the fix:
HOOKS="base udev autodetect block modconf filesystems keyboard fsck"
After the fix:
HOOKS="base udev block autodetect modconf filesystems keyboard fsck"
Running mkinitcpio -p linux to regenerate the initramfsthen fixed the problem permanently.
Now it kinda works (to say the truth, it says that the nvidia card i've got in my other pc is not supported, but it's still a step forward: i think when i'll try it in the cab it will work ;) )
If someone is interested i can post/share the 2 initramfs.
« Last Edit: December 26, 2016, 04:04:36 pm by Francesco »
Beaps
  • Last login:July 09, 2020, 10:46:40 am
Re: [solved] GroovyArcade Linux - /dev/disk/by-label/GA not found
« Reply #2 on: April 17, 2020, 11:37:00 am »
I've got this error also, anyone know how to solve it. It says its solved but I dont get what I have to do.
Francesco
« Reply #3 on: April 18, 2020, 04:27:21 am »
I solved doing what i quoted. Unfortunatly i don't remember that much.
