Author Topic: How to configure Supermodel 64 emulator in Maximus Arcade  (Read 6442 times)
xarcade_Darren
  • Last login:December 22, 2016, 12:11:41 pm
« on: December 22, 2016, 11:37:10 am »
Hello,  I am trying to configure the supermodel 64 bit emulator in Maximus Arcade.  The goal is to run the Star Wars Trilogy game..   I would love suggestions on how to accomplish this or if you are aware of another way to run Star Wars Trilogy other suggestions are welcome.   The issue I have is around running full screen (the sega emaultor opens in a window) and the appropriate mappings for the xarcade controls.
Any help would be appreciated
Thank you
Darren
« Last Edit: December 22, 2016, 11:40:06 am by xarcade_Darren »
bvander
  • Last login:January 11, 2017, 10:39:54 am
Re: How to configure Supermodel 64 emulator in Maximus Arcade
« Reply #1 on: January 06, 2017, 09:38:00 am »
I am trying to figure this exact thing out.  If I do, I'll be sure to chime in.  And if you figure it out, please pass this along.
Good luck
MikeMelga
  • Last login:June 12, 2023, 06:24:13 am
« Reply #2 on: January 10, 2017, 06:58:32 am »
Hi.
I am very new to MA but I guess I figured it how to add Supermodel3 to it:
1 - Since MA does not support it... choose another emulator to trick it. In my case I've choosen Atari 5200.
2 - Configure Atari 5200 parameters for supermodel. In my case I have:
%file -res=640,480 -fullscreen
because I want to run it at 640x480 in fullscreen
Optional:
3 - Extract the Maximus Arcadius.zip file in the Skin directory and replace Atari 5200 pictures by Model 3 pictures. If you want I'll send you my custom made Supermodel3 pictures.
4 - Use a program like Hexedit to edit the Maximus Arcade.exe file and replace the 'Atari 5200' string with 'Sega Mod3' ---> Use it caution. Backup first!
These last two will show proper pictures and names in the frontend.
bvander
« Reply #3 on: January 10, 2017, 10:40:27 am »
Thanks for that.  I'll give it a try and see how it goes
