Author Topic: Arcade Power Supply (PSU) voltages question.  (Read 3490 times)
pharoah007
  • Last login:June 29, 2017, 07:27:26 pm
  • Why buy it when you can BUILD it!
« on: December 21, 2016, 09:44:53 am »
My PSU has a slight variance between -5V and +5v
When I set the +5V to exactly +5V, the +12V is right at 11.98V, good.
However,
When I set the +5V to exactly +5V... the -5v is only -4.5V
Is this variance normal?  I do not want to crank up the +5 volt to get the -5V up to -5V or I may fry the PCB.
Thanks all.
lilshawn
Re: Arcade Power Supply (PSU) voltages question.
« Reply #1 on: December 21, 2016, 03:32:58 pm »
set the +5 voltage to 5.0...connect and power on the game. measure the voltage ON THE BOARD and set the voltage there up to 5.1 (just to be safe) forget the rest.
-5v is normally only used in the audio amp section. as long as it's below 0 volts it's fine. (and sometimes not even used at all depending on the board.)
