Author Topic: Any changes in the way Save/Load Game works in MAME?  (Read 1650 times)
  • Last login:Yesterday at 06:53:06 am
« on: December 16, 2016, 09:40:45 am »
IIRC, last time I messed with it you were required to have a dedicated separate key for each slot to save or load from.
(vs being able to navigate slots with the joystick)
It's been a long time.  I could be remembering wrong, but I do remember that the way it worked was not conducive to incorporating it into a cab.
Has the way any of that is handled changed in newer versions of MAME?
(my cab is on v.146)
EDIT: Does it also work for the console emulation in MAME?
« Last Edit: December 16, 2016, 09:46:42 am by BadMouth »
DrakeTungsten
  • Last login:August 14, 2022, 06:36:45 pm
  • I effed with the wrong person!
    • No Quarter - a basic FE, WIP
Re: Any changes in the way Save/Load Game works in MAME?
« Reply #1 on: December 22, 2016, 06:32:52 am »
I use version 177, and the process is still as you describe. This is also how it saves for console games.
Titchgamer
« Reply #2 on: December 22, 2016, 09:11:10 am »
Not used it for years but dont you press the save button then press a number to save it to?
Then the same for loading.
« Reply #3 on: December 22, 2016, 09:50:12 am »
Thank you.
