Author Topic: PC in a model 3 cab  (Read 3691 times)
PC in a model 3 cab
« on: December 15, 2016, 02:16:45 pm »
I have a Daytona USA 2 cab, with both Daytona 2 and SCUD/Super GT motherboards/sound cards. I toyed with the idea of putting a PC in there to replace the Model 3 mobo.
I also have an immersion PCB but have no clue on what all is involved on making it work with the Daytona 2 wheel or how to get Force Feedback going. I'm on the look out for a dead model 3 mobo to steal the filter board from, so I can make the conversion to a PC fully reversible.
I read through the "newb FAQ" but it was all about model 1/2 cabs and the L2M2 which wont work on a model 3 cab.
I have the following hardware:
immersion PCB (single board version)
APAC
PAC LED
IPAC2
so I know it should be possible.
  • Moderator
Re: PC in a model 3 cab
« Reply #1 on: December 15, 2016, 04:15:55 pm »
As far as I know, nobody has come up with an interface for Model 3 hardware.
SailorSat does have the knowledge to do it, but hasn't had a big enough reason to bother.
It won't work with the Immersion board because the motor is 120V AC (or something like that) and uses a clutch mechanism whereas the Immersion board is made to work with 24V DC.
You can swap in a happ FFB setup and use the immersion board.
Or you could use a different interface and make do without FFB.  :'(
I have an Initial D CP (less wheel) that I've been trying to get rid of forever.
  • Moderator
« Reply #2 on: December 15, 2016, 04:20:16 pm »
Relevant: http://forum.arcadecontrols.com/index.php/topic,145000.msg1507622.html#msg1507622
I'm not sure how big of a difference there is between the Model 2 & Model 3 hardware.
(although I do have both on the parts pile)
Read through the thread and look for her links.
She's using the arduino and vjoy for input, but has a separate program having a Teensy output the ffb signals to the original FFB board.  (I think)
« Last Edit: December 15, 2016, 04:24:57 pm by BadMouth »
SailorSat
  • Last login:Yesterday at 10:41:24 pm
    • For Amusement Only e.V.
« Reply #3 on: December 15, 2016, 08:11:01 pm »
Forget that Arduino + vJoy setup - The teensy2++ handles inputs and outputs (and has been tested with model3 - a scud race to be exact).
But I still have not done a complete wiring diagram or step-by-step howto :)
I do all that stuff even without a Joystick ;)
Soft-15kHz, cabMAME, For Amusement Only e.V.
« Reply #4 on: December 15, 2016, 08:23:14 pm »
arian you are amazeballz.  Im willing to buy one prefabbed :)
