Author Topic: DreamGear Mini Retro Arcade Machine Pi Zero conversion  (Read 6919 times)
  • Last login:Yesterday at 06:57:41 am
« on: December 10, 2016, 10:45:42 pm »
I might not bother finishing this one, but figured I'd post the pics to put the info out there for other people.
I don't think I'll use the thing after it's done, so I'm not sure it's worth buying the parts to finish it or the time it will take to configure it.
This started with a DreamGear Mini Retro Arcade Machine that I picked up on clearance at Target for $15.
I bought it because it was cute and included 300 games.  The games all suck pretty bad though.  A lot of them are limited to one static playfield.
The controls feel good though, much to my surprise.
Disassembly:
Remove screws under battery cover.
Cut these foam strips across the seam underneath them.
The top is held in place by two tabs.  Either free up the bottom and lift upward, or pry the top panel upward.
The bottom panel is held in place by melted tabs.  They could be ground down, but It doesn't really need to be removed.
On the back panel: On/Off switch, speaker, battery compartment
In the cab: Main PCB is mounted behind the screen, a ribbon cable goes to the CP which has it's own PCB.
The CP PCB is just buttons and switches though, so the ribbon cable can just be hacked off and attached to a different interface.
The two things sticking down are LEDs to illuminate the little logo on the front.
The PCB must be used in multiple devices.  It looks like it might fit in the Gameboy knockoff DreamGear makes.
The CP slides into a slot from the back.  It has tabs on it that extend half way up the back of the monitor bezel.
These tabs have adhesive on them gluing them to the back of the monitor bezel, but they come apart without damage.
The screen is 2.5"  I do not see a way to use it with the Pi Zero.  I do not know much about driving screens though.
The joystick has arms underneath the CP that activate pads similar to a gamepad.
This board looks fairly labor intensive for the manufacturer to build.
I don't see anything on here that means anything to me, but maybe it will to someone else.
Ready for new guts:
I don't think a full size Pi would fit, but the Pi Zero wouldn't be a problem.
Reasons I'll probably shelve the project for the time being:
1. The Pi Zero outputs digital audio through HDMI, but doesn't output analog audio for a headphone like the regular Pi.  Building the audio circuit is simple, but it takes up room and then it has to be configured on the Pi.  There is a guy selling a tiny board on ebay that uses surface mounted parts.  Even if I had that, I might still need a little audio amplifier which will also need to be powered.  The charging/power board I already bought can supply an amp if needed.
2. I don't see a way to use the original screen and 2.5" screens with AV input are more expensive than I expected (around $45).  Most of the Pi Gameboy type builds use the pins on the pi to interface the screen, but that bypasses the GPU (from what I understand).  I'd get more bank for my buck using the AV connection.
3.  I have no experience with the Pi or Linux.  I was hoping I could download an SD card image, then plug 'n play.  The audio will have to be set up though.  I also don't want any emulators other than MAME, so I don't want them showing up in the menu.  I already have the Pi, so I will experiment and see what I'm getting into.
Mostly I hate to keep sinking money into something that I know I won't use for more than a few minutes after it's completed.
I'll probably have $100-125 in this thing by the time it's finished.  I could build a real cab (using parts I have laying around) for that much.
I could use some of these components on other projects that I'll actually get more use out of.
« Last Edit: December 10, 2016, 10:52:28 pm by BadMouth »
stigzler
    • Mago Arcade
Re: DreamGear Mini Retro Arcade Machine Pi Zero conversion
« Reply #1 on: December 13, 2016, 03:01:28 am »
Shame youre shelving this. Would have been good to have seen it completed...
  • Last login:Today at 09:29:01 am
« Reply #2 on: December 13, 2016, 07:00:05 am »
I is good to know when to cut your losses.
JDFan
« Reply #3 on: December 13, 2016, 07:59:14 am »
Since you have the pi zero already and probably have several of these other parts laying around ( or could get them from China for a few bucks if you wait for them to get there ) you could always build yourself a Nes cart console or similar out of it.
! No longer available
« Last Edit: December 13, 2016, 08:05:03 am by JDFan »
thomas_surles
« Reply #4 on: December 13, 2016, 08:03:46 am »
How about using the guts and screen from one of these? Then shelf this case for a portable pick project.
http://www.ebay.com/itm/252322799153
« Reply #5 on: December 15, 2016, 10:56:08 am »
That is tempting.  Trying to find teardown pics to see if the screen is soldered directly to the main pcb.
The 16bit PXP sega version looks like it's made by the same company and the screen is connected via ribbon cable.
It would definitely be easier from a software standpoint.
I plan to play around with the Pi Zero this weekend and see how much trouble it's going to be to configure how I want.
If I get that set up, I'll probably just shelve it until I feel like blowing the money on a screen.
If I can't figure it out in a few hours, then I'll probably order one of those.  The fact that it takes the same voltage as this battery compartment allows for is a big plus.
Thanks.
« Last Edit: December 15, 2016, 11:02:26 am by BadMouth »
stigzler
    • Mago Arcade
« Reply #6 on: December 15, 2016, 01:54:58 pm »
Happy that this is close to resurrection.
