Author Topic: Tips/advice wanted on matching jpeg graphics to my cabinet sides  (Read 2369 times)
jimmer
  • Last login:February 17, 2025, 02:48:38 pm
  • I want to play Defender like at the arcade.
« on: November 26, 2016, 08:07:50 am »
I have Illustrator and Photoshop, but all I've done so far is play with vector graphics in Illustrator.
What I want to do now is be able to take a big picture and see what part of it would look like on my cab side. Like this guy has done, I'm aiming for something like options 2 and 3.
Can anyone give me a quick pointer on the steps I need to take. Even knowing the terminology would help me search how to do it.
thanks.
On forums jimmer speaks for himself as a Defender fan, not as proprietor of www.jbgaming.co.uk  << Is that advertising or disclosure ? or both ?
thomas_surles
Re: Tips/advice wanted on matching jpeg graphics to my cabinet sides
« Reply #1 on: November 26, 2016, 10:05:57 am »
You could take a really good straight picture of the side of your cab and cut it out in photoshop and put the image on a layer behind it. Assuming this is just for a reference to see how it looks.
jimmer
« Reply #2 on: November 26, 2016, 01:18:50 pm »
I've got the side profile of my cab in various formats. A vector path in Illustrator, and I can make pngs from that (I'm sure).
What you are suggesting is to make the side of the cab transparent (or is a hole something else), and look through at the graphics on the layer below.
I hadn't thought of that because I was working from the example I posted which looks like the cab side is 'solid' and the background is transparent, and then the graphics have been cast on to it.
I will have a play in photoshop.
thomas_surles
« Reply #3 on: November 26, 2016, 01:28:36 pm »
Yeah basically. I would cut it out. Paste it on a blank background and then cut it out again and have the image showing through the hole you cut out. Something simple like that.
