Author Topic: Router questions  (Read 1854 times)
Yander
  • Last login:July 08, 2013, 08:00:14 pm
Router questions
« on: January 21, 2004, 06:45:25 pm »
I know I need a 1/16" bit for t-moulding but what bit do I need to route out the hole for my joysticks on the bottom of the control panel so the shaft is long enough.
Tilzs
  • Last login:February 16, 2011, 10:41:56 am
  • Neat
    • Cocktail Arcade
Re:Router questions
« Reply #1 on: January 21, 2004, 07:38:23 pm »
What joystick are you useing?
The bit you want is a straight/plunge cutting bit.
JustMichael
  • Mmmmm!! Cheesecake!!
Re:Router questions
« Reply #2 on: January 21, 2004, 09:33:34 pm »
A hammer and chisel will also work...   ;)
Yander
Re:Router questions
« Reply #3 on: January 22, 2004, 01:21:42 pm »
Yeah, but how well
I'm using happ competition joysticks.
Thanks for the advice.
slicer_d
  • Last login:November 06, 2013, 12:51:11 am
  • Yay n' stuff
Re:Router questions
« Reply #4 on: January 23, 2004, 12:24:06 am »
I was in the same position you were in a while ago I had to use a chisel becuase it was an already assembled control panel you can get it pretty even if you have no access to a router and no money to buy one I would suggest getting a cheap chissel.
As for a router bit I borrowed a non plunging router but it works anyway and the bit I have looks basically like a short drill bit that is flat on the bottom.  The little box for it says its a 1/4" steel straight bit.  It has worked for the couple joystick step downs I have had to make.
If you havent bought a bit yet I would suggest getting them from this website as far as price goes they are the cheapest I have seen.
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_slot.html
#5341 is the one I got but get the 1/2" one if you need it.  I have used mine and it works great.
Good luck!
JustMichael
Re:Router questions
« Reply #5 on: January 23, 2004, 07:58:56 am »
Yander,
The pic above was done by Oscar.  He tried using a hammer and chisel just for kicks in response to my suggestion in this thread.
Yander
Re:Router questions
« Reply #6 on: January 23, 2004, 08:30:54 am »
Impressive picture. I will probably go the router route. (play on words not intended) Instead of the chisel unless I can't find anyone with a router. (Im sure I will though)
It's good to know that the chisel will work if needed though.
Also nice website for the bits.
PaulG
  • Last login:April 10, 2007, 03:25:56 pm
Re:Router questions
« Reply #7 on: January 23, 2004, 01:09:42 pm »
So is MDF short for Melamine board?  I've got my parts on the way and am not thrilled about how I'm going to actually mount the joysticks (3/4" melamine).  I'd love to use Oscar's method, but is MDF melamine board, or won't this work for me?
PS  I'm trying to avoid buying a router just for this.  I've got enough money sunk into it.
flipped cracker
  • Last login:September 30, 2011, 03:35:54 pm
  • ubercade
    • http://flippedcracker.net/
Re:Router questions
« Reply #8 on: January 23, 2004, 01:13:06 pm »
MDF stands for Medium Density Fiberboard.
