Author Topic: Nanao MS9-29 Yoke issue  (Read 2274 times)
segasonicfan1
  • Last login:April 12, 2020, 02:39:42 am
« on: November 23, 2016, 08:07:22 pm »
I have tried two working chassis so the problem definitely appears to be the tube or (more likely) the yoke.  Anyone have a suggestion of where to start?  I've only worked on the chassis before.  Monitor shuts off after ~2 sec.  Here's some pics.
Any help is much appreciated!!!
-Segasonicfan
« Last Edit: November 23, 2016, 08:10:31 pm by segasonicfan1 »
grantspain
  • Last login:Yesterday at 10:42:13 am
Re: Nanao MS9-29 Yoke issue
« Reply #1 on: November 24, 2016, 01:04:23 am »
read the vertical winding of the yoke,should be about 9-10ohms
segasonicfan1
« Reply #2 on: November 25, 2016, 04:31:35 pm »
Thanks!  Do you know winding value for the H yoke?  I think its an H collapse (the pics show the monitor tated).
grantspain
« Reply #3 on: November 25, 2016, 06:05:51 pm »
oh yes,must have been half asleep when i first viewed this
horizontal deflection failure will be down to either bad/burnt yoke connector,bad solder joint on chassis or flyback faulty
the hot being short ciruit would put the chassis into ocp mode
segasonicfan1
« Reply #4 on: November 25, 2016, 10:55:11 pm »
Thanks for the reply.  Do you know the reading for the H winding on the yoke?
The chassis is good, there have been 2 working MS9-29 chassis tried on this tube now.  So it can't be the HOT or Flyback, it has to be either the yoke or the tube itself.  I somehow doubt that H collapse could be caused by the guns going bad though.
grantspain
« Reply #5 on: November 26, 2016, 05:24:14 am »
about 0.8 ohm
you could remove the yoke and check for corrosion
have used the same remote board and cable to test each chassis
