Author Topic: Pi Noob Questions for a mini Pi Zero build  (Read 4726 times)
« on: November 23, 2016, 03:03:14 pm »
I have one of these which I have played all of two minutes before deciding that the included games aren't worth playing for more than two minutes:
Despite already having piles of unfinished projects, I'm kicking around the idea of getting some real classics on it.
From a little bit of research, here is the direction I'm thinking of going:
Pi Zero - as long as early 80's classics are playable, I'll be happy with it.
I don't think a full size Pi will fit.
320x240 Screen with A/V input - From what I read this still utilizes the GPU whereas one driven by the pins on the zero would not, and would require software installation.  Is RGB an option?  I have a spare mini slg scanline generator kicking around (would require higher resolution)  Not sure which size screen will fit yet.
Kind of deciding whether I want to take on the project or not at this juncture.
Minimus AVR programmed using KADE software - I assume this is easier than using pins on the Pi Zero?  The controls on the mini arcade are already on their own PCB, so it should just be a matter of wiring it to the AVR.  I already have a couple of these in a parts drawer.
The little arcade machine currently takes 3 AAA batteries which will give me 4.5v.
Is this enough, or does it need to be taken up to 5-6v?
I have no experience with Linux or pi.  I'm counting on just downloading a card image and having things be fairly plug and play.
Any advice appreciated.
« Last Edit: November 23, 2016, 03:05:23 pm by BadMouth »
Re: Pi Noob Questions for a mini Pi Zero build
« Reply #1 on: November 23, 2016, 04:41:02 pm »
Ordered a Pi Zero and this voltage converter/charging circuit from adafruit: [url]https://www.adafruit.com/products/2465]https://www.adafruit.com/products/2465] [url]https://www.adafruit.com/products/2465[/url]
With that, I should be able to set the pi up and see if it will work the way I want it to before spending money on a screen.
(maybe the one already in the little machine can work.....)
I'll start a build thread when I take the case apart.
EDIT:  It seems audio might turn out to be the biggest PITA...  :-\
« Last Edit: November 23, 2016, 04:45:20 pm by BadMouth »
moonlight23
  • Last login:June 14, 2017, 05:43:56 pm
« Reply #2 on: February 21, 2017, 10:12:35 pm »
Start
3 Completed ;)
« Last Edit: February 21, 2017, 10:14:17 pm by moonlight23 »
