Author Topic: Retro themed bartop project (Suggestions, advice, criticism please)  (Read 8169 times)
gomeq
Hey guys, I'm currently working on a arcade bartop with the working title 'Retrocade'. I want to have a 70's styled theme with minimal artwork.
I already ordered some orange (primary) and black (secondary) buttons to go with the theme.
Also did some artwork drafts but for now I'm kinda stuck and out of inspiration. Hoping you guys will have some feedback. Don't be shy, all your feedback is welcome as long as it helps me to get this going again.
The dark wood grained background is something that must stay in place.
sidepanels
control panel top & front
marquee
For the name things in the direction of this list is what I'm looking for.
Retrocade
Coin Up
Arcade heroes
Masters of arcade
1978 (my year of birth)
« Last Edit: November 23, 2016, 06:38:10 am by gomeq »
gomeq
Re: Retro themed bartop project (Suggestions, advice, criticism please)
« Reply #1 on: December 15, 2016, 02:59:35 pm »
Test fitted some artwork. What do you guys think?
acvieluf
  • Last login:April 09, 2026, 08:19:34 am
« Reply #2 on: December 15, 2016, 03:02:56 pm »
Looks AMAZING! I love woodgrain.   Looks odd with the black bezel, though.  Is there something going in there?
Ian
  • Last login:February 27, 2026, 11:36:05 pm
« Reply #3 on: December 16, 2016, 12:39:30 pm »
I am definitely digging the artwork~!
vwalbridge
« Reply #4 on: December 16, 2016, 01:01:19 pm »
I'd have the wood grain on the sides go vertical instead.
krangbrain
  • Last login:June 22, 2020, 05:36:57 pm
« Reply #5 on: December 16, 2016, 02:46:49 pm »
I like it a lot!  :applaud: Only thing I would suggest you consider changing is the marquee. I'd get rid of the wood grain and swap it out for one of your lighter colored ones, like the 4th one from the top. Just make sure the stripes are the same as the sides.
Haloman800
  • Last login:February 07, 2020, 12:40:00 am
  • Awfully Awesome
« Reply #6 on: December 18, 2016, 01:12:25 pm »
This is one of the sleekest bartops I've seen. Would you release the artwork files/build plans you used? My next project will be a bartop and if it's okay with you I definitely want to use this design
Sent from my SM-G935V using Tapatalk
« Reply #7 on: December 18, 2016, 01:35:23 pm »
Agreed. I love the look of this, but the grain should be vertical to match the longer side of the cab.  I do love the color scheme.  Great job!
g5k
  • Last login:February 20, 2023, 11:24:46 pm
« Reply #8 on: December 18, 2016, 04:19:11 pm »
Love the wood grain nice to see another fan (I've saved some actual veneer wood from our kitchen for building something down the track).
One design suggestion would be to take the line you are establishing in your marquee and continue that across top then you could bring down the back as a spine that the curves and wraps around the side. Would be a bit Atari in terms of effect. Love the palette you've established nice one.
gomeq
« Reply #9 on: December 19, 2016, 02:10:07 am »
I will be releasing the files when I'm finished. Please follow my thread in the projects folder. http://forum.arcadecontrols.com/index.php/topic,151614.0.html
Thnx for all your feedback guys. I will make a version with the woodgrain going vertical. Don't know if the light version of the marquee will look OK but will test that as well.
What do you guys think about tmolding. I have my doubts about the color. Orange, dark brown or maybe even black.
Monkeyvoodoo
  • Last login:November 16, 2024, 01:36:41 am
  • I swear I can stop at one. Or two.
    • threefoldhorse Custom
« Reply #10 on: December 22, 2016, 12:04:58 am »
Have you thought about chrome t-molding? My TNQ cab was going to have those.
Posted from a rotary phone
gomeq
« Reply #11 on: December 22, 2016, 02:02:30 am »
I think that won't match the theme
gomeq
« Reply #12 on: December 29, 2016, 10:29:53 am »
Changed the direction of the wood grain and this better. Thnx for the tip guys. Don't like this marquee so I'm going to stick with the other one.
gomeq
« Reply #13 on: January 18, 2017, 05:42:55 am »
I want to order my t-molding this week but still not sure what color i want to use. Can you give me some feedback on this. On the picture below you'll see some small pieces of example t-molding.
Two next to the marque and two next to the monitor bevel.
