Author Topic: Model2 crashing when selecting Control Config  (Read 2138 times)
bcgamer
  • Last login:September 30, 2021, 02:33:37 pm
« on: November 15, 2016, 07:12:23 pm »
Why is model2 doing this all of a sudden
Load game- loads no problem
Go up to game/config control
Emulator crash.
Every time.  Yesterday wasn't an issue.
I'm using the multicpu version.
Tried both, no dice same thing.
Re: Model2 crashing when selecting Control Config
« Reply #1 on: November 15, 2016, 08:03:15 pm »
Do you have more than one controller connected?
bcgamer
« Reply #2 on: November 15, 2016, 09:03:56 pm »
Yes I have 2 Xbox 360's
I'm taking that's the issue?
Should the 2nd be off when setting them?
« Reply #3 on: November 16, 2016, 06:19:11 am »
Could be.  Just trying to get more info.
People have reported that happening when they have a wheel and other controllers connected.
You can map all the controllers, but have to do them separately, one at a time.  Then plug them all back in and run the game.
If those 2 Xbox controllers are the only ones you are using, xinput should be enabled in the cfg file.
bcgamer
« Reply #4 on: November 16, 2016, 10:03:17 am »
What I've done is take a separate build and did them again
I'm setting up model 2 racing games in HS for multiplayer so I need to have multiple copies of the emulator and set slave/controls for each one
Seems to be getting along for the most part now...
