Author Topic: rowe r-8o dc to dc converter  (Read 2438 times)
tigger
  • Last login:November 08, 2016, 04:28:01 pm
« on: November 06, 2016, 08:00:55 pm »
New to the forum, I usually work on the older Wurlitzer's from the 40's & 50's, but took on this project for a friend, its a Rowe R-80, the dc to dc converter was corroded to where some of the transistors broke off the board. I would like to replace them all, have the manual, but its not listed, and I cannot read any numbers on the transistors, does anyone know their valve or where I might find a converter
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: rowe r-8o dc to dc converter
« Reply #1 on: November 07, 2016, 06:07:22 am »
Hi tigger,
The dc to dc converter is not required for the operation of the jukebox, its only function is to retain selections in memory in the event of a cut in power to the jukebox.
The dc converter was only used on the R-80S & R-81 jukeboxes where the cut down memory unit was used.
The dc to dc converter schematic and parts list is on pages 2-38 & 2-39 of the R-81 manual.
Regards
Alan
Alan Hood
ami-man
UK
tigger
« Reply #2 on: November 07, 2016, 07:00:13 pm »
Thanks Alan,
  I thought that was the case, I have the r-80 manual, I'll have to look around for a r-81, Thanks again..  :applaud:
ami-man
« Reply #3 on: November 08, 2016, 06:20:02 am »
Hi tigger,
The R-80S (1976) was supplied using the new system of the 1200 mechanism intended for the 1977 R-81.
My guess is that Rowe Ami had a surplus of R-80 cabinets so used them up as the R-80S, all that was required was a new loom and a change of keyboard casting and the new mechanism and boards.
Regards
Alan
Alan Hood
ami-man
UK
