Author Topic: Using different EMU drivers in dual boot system  (Read 1781 times)
ckong
  • Last login:October 19, 2020, 06:48:09 pm
  • Retro Games forever!
« on: November 05, 2016, 05:48:59 pm »
Hi guys, until now I am running XP32 and GM 0.166 with a HD 4550 (sometimes a 4670) graphics card and CRT Emu driver 1.2a (catalyst 9.3) on a NAC and a Blast City (both in 15K). And I love it.  :)
However, because my PC is capable in doing more, like playing hires PC games and because I want to experiment with Windows 7 64bit and a newer 64 bit GM 0.171 (with Emudriver 2.0 Beta 8) I just made a dual boot system XP 32bit / W7 64bit. And I will later probably get a more modern HD card, 6.... series or so.
I want to follow this guide to set everything up for a HD 4.... card: http://geedorah.com/eiusdemmodi/forum/viewtopic.php?pid=1016#p1016
But before I do that I checked the device manager in W7 to see if the fresh W7 did manage to install all needed hardware drivers. And to my surprise I saw that the display adapter is the Ati Radeon HD 4670 that I use in XP. I didn't know that W7 'borrows' drivers used in other Windows versions.
Anyway, the key question is: if I install emu driver 2.0 B8 to use in W7, will I then still be able to use XP also with the appropriate 1.2a Emudriver?
« Last Edit: November 05, 2016, 06:38:27 pm by ckong »
Calamity
  • Moderator
  • Last login:Today at 04:45:26 am
  • Quote me with care
Re: Using different EMU drivers in dual boot system
« Reply #1 on: November 07, 2016, 05:02:19 pm »
Windows installations won't grab drivers from each other. So your XP installation won't be affected.
Windows didn't borrow the drivers, it already has built-in drivers for most common hardware.
Steps to create a log:
ckong
« Reply #2 on: November 09, 2016, 01:14:16 pm »
