Author Topic: PS3 start with wheel (logitech driving force gt wheel) any way to do that?  (Read 5548 times)
redketchup
  • Last login:September 30, 2021, 09:22:45 pm
Hi
I will redo my xbox racing cab, and I will use my PS3 with a logitech driving force GT wheel.
I was planning to used my PS button to boot the PS3 with my wheel, but it doesn,t work... it work with the PS button from a gamepad, but not from the wheel.
Any Idea? I don't want to go into the cab to boot the PS3 and I don't want to have a game pad lying around only to boot it...
redketchup
Re: PS3 start with wheel (logitech driving force gt wheel) any way to do that?
« Reply #1 on: November 02, 2016, 09:20:32 am »
Any idea
Boomslang
  • Last login:August 25, 2026, 05:20:44 am
« Reply #2 on: November 02, 2016, 05:04:21 pm »
I have a way if you wanna load it from a frontend etc from pc
buttersoft
  • Last login:Yesterday at 11:22:06 pm
  • Is running at 15kHz
« Reply #3 on: November 03, 2016, 06:14:21 pm »
Boomslang I'd be keen to hear about that.
Redketchup - if the function isn't there it isn't there. I have a third-party usb board for PS3 with a PS button, and while the button works in-game, it won't start the system. I'm not sure what's missing, but I doubt it would be an easy fix. If I had to fix it, I'd chop up a PS3 controller and put bits of it inside the wheel, assuming there's room.
thomas_surles
« Reply #4 on: November 03, 2016, 06:59:10 pm »
Lazy fix is to just keep a ps3 controller nearby.
Boomslang
« Reply #5 on: November 03, 2016, 08:40:28 pm »
Requires having a ir kit and ps3 harmony adapter but it works well
Details are in this post
https://www.hyperspin-fe.com/forums/topic/935-my-attempt-at-hyperspin/
  • Moderator
« Reply #6 on: November 04, 2016, 12:21:46 pm »
This idea is out there, but maybe a door lock actuator positioned so it presses the power button.
You could use a weaker voltage or springs to keep it from hitting the button too hard.
shaolindrunkard
  • Last login:February 12, 2026, 11:54:11 am
« Reply #7 on: November 04, 2016, 09:07:25 pm »
Get a cheap ps3 contoller, open it up, figure out the voltage on the battery, wire it up to a wall wart. Solder a couple wires to the home button ontacts, solder the other end to any kind of button and mount it where you want it. Done.
« Reply #8 on: November 04, 2016, 11:14:30 pm »
Yup.  You can get ps3 knock-off gamepads for around 3 bucks on eBay and foreign sites.
redketchup
« Reply #9 on: November 07, 2016, 12:26:52 pm »
look like not all the ps3 controller can boot the ps3 with the home button... not sure i want to have to buy 3-4 controlller before i find one working.
shaolindrunkard
« Reply #10 on: November 07, 2016, 01:39:28 pm »
Then use an official one.
redketchup
« Reply #11 on: November 07, 2016, 01:47:22 pm »
I already try with a dualshock3, but there is almost no room for soldering cable...
