Author Topic: Help finding right Router Bit Size for T-Molding Channel  (Read 8359 times)
usaf-lt-g
  • Last login:October 04, 2024, 10:05:30 pm
« on: October 25, 2016, 03:46:22 pm »
Hi Guys,
I need some help finding the right Router Bit Size for a Customer Control Panel I'm finishing. I have a 1/2" thick of board that has a 1/8" Scratch Resistant Plexi that will go on top (Thus bringing the total thickness when both layers are attached to 5/8"). I have 5/8" T-Molding I am applying to the edge. Image of Specs of T-Molding below.
What size slot cutter router bit would I need to cut the grove for this? This image says the thickness of the T-mold is 7/64. Is there a bit I can pickup from Home Depot / Lowes / Menards / Ace or is this something I have to special order?
Your help is GREATLY appreciated! Thanks!  :cheers:
UEDan
  • Last login:November 10, 2019, 05:54:08 am
Re: Help finding right Router Bit Size for T-Molding Channel
« Reply #1 on: October 25, 2016, 04:00:31 pm »
This is where I picked up my slot cutter:
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_slot.html#anchor_slotct3w
For 7/64... I would go with the 3/32" 3 flute
  • Last login:August 31, 2026, 01:17:02 pm
usaf-lt-g
« Reply #3 on: October 25, 2016, 04:12:55 pm »
Get the set from Harbor Freight like everyone else...
http://www.harborfreight.com/carbide-tip-three-wing-slotting-cutter-router-bit-set-7-pc-68871.html
Awesome Thanks! I have a Harbor Freight right down the road! ;) 3/32" 3 Flute is what I'll use! Thanks guys!
JDFan
« Reply #4 on: October 25, 2016, 04:45:30 pm »
Don't forget they usually have a 20% off one item coupon floating around that would save you $5 !
Slippyblade
« Reply #5 on: October 26, 2016, 12:41:54 am »
I got mine from Groovy Game Gear.
usaf-lt-g
« Reply #6 on: October 26, 2016, 09:37:25 am »
Double awesome!  :applaud:
I already found it, and actually never realized they typically have a 20% coupon. I'm always going there for odd tools I need to work on the car. Thank you!   :woot
