Author Topic: 1st Build (Vewlix Inspired)  (Read 21966 times)
atxscarface
  • Last login:February 16, 2024, 06:40:56 pm
« on: October 19, 2016, 11:26:55 am »
The plan, features 42" Westinghouse LED TV
Building the base
Sides cut but not routed
Sides routed and mounted, monitor fitting
After the monitor fitting I didnt like how low it sat, so I added some block shims to lift it a bit
Marquee top build
Top added
Backside
Sideview
Speaker cutouts
Current status of the project
Todo:
-Control panel (Will be a dock of sorts for my sticks already made)
-Filler and sanding where needed
-Cut front door in half
-Paint
-Mount front door and backside door
-Add hardware (92mm Intake fans, 120mm exhaust fans, door handles, lighting)
-Speaker mounting
More will come im sure.
  • Last login:August 31, 2026, 01:17:02 pm
Re: 1st Build (Vewlix Inspired)
« Reply #1 on: October 19, 2016, 11:29:08 am »
You cut some boards, I like you already.
atxscarface
« Reply #2 on: October 19, 2016, 11:35:38 am »
Yessir! No CNC machine here. All cut by hand, hence so crooked.... ;D
  • Last login:August 25, 2026, 02:00:37 pm
« Reply #3 on: October 19, 2016, 12:25:56 pm »
No matter how you do it, cutting boards is a refreshing change of pace.
killerinstinct
  • Last login:August 28, 2021, 11:24:17 am
« Reply #4 on: October 19, 2016, 12:34:48 pm »
I did the same few years ago No CNC also
smass
  • Last login:December 05, 2024, 06:12:33 pm
  • Cheapskate Arcade
« Reply #5 on: October 19, 2016, 01:31:25 pm »
Nice work so far.  I like your solution for the curved top edge.  :)
atxscarface
« Reply #6 on: October 26, 2016, 03:34:50 pm »
Control Panel Build
Attaching CP to cabinet
Support beam for CP attachment
Finishing CP build
1st Test Build before Paint
USB hideaway
So far im happy with the results given I dont have much woodworking skill nor tools to make it look like most I see on here. Trying to come up with a color scheme as I want something a bit universal as far as the cabinet so that I can rely mainly on the dockable sticks for customized colors.
rablack97
« Reply #7 on: October 26, 2016, 07:56:04 pm »
Man that hinge setup looks dangerous, those 9 screws could easily be stripped out and the cp hit the floor.
And you had me until you put fight sticks in it........i'm sad, so so sad now  :'(
menace
« Reply #8 on: October 27, 2016, 07:04:07 am »
Nice build!  I agree with the sentiment above--MDF is not known for its pull out resistance and after two adults put their weight on that panel, those screws will give--slowly at first then all at once.  I would install a brace or bracket on the sides that's removable that could take the weight off those hinges.
I love the fold up design though--clever way to get the big bugger through doors.
atxscarface
« Reply #9 on: October 27, 2016, 10:27:08 am »
Yea I hear ya both. That is what I was thinking I am going to have to deal with eventually even though the 2x4 placed underneath the top of the base is good for now to drill in the wood screws, this wont last. I was thinking either replacing the wood screws with machine screws and interlocking nuts to ensure the bolts stay in place. I also thought as @menace did and add some sort of bracket on the side but I think this would take away from the minimal look of the cabinet. I really didn't want to use the hinges at all but I really dont see much other choice.
Maybe something like this on the side, to take off some of the weight on the hinges?:
@rablack97
Not sure what else you expected to go in there except fightsticks?
« Last Edit: October 27, 2016, 10:28:41 am by atxscarface »
« Reply #10 on: October 27, 2016, 10:34:23 am »
either of you two have the plans for that?
atxscarface
« Reply #11 on: October 27, 2016, 10:49:00 am »
Plans for what?
« Reply #12 on: October 27, 2016, 12:15:40 pm »
design diagrams and measurements for the cuts
atxscarface
« Reply #13 on: October 27, 2016, 12:21:59 pm »
My build is based off Donovan Myers, but slightly different as far as the CP and bigger scale to fit a larger TV. I think Donovans was for a 32" TV:
http://www.donovanmyers.com/arcade/x24VewlixPlans.pdf
« Reply #14 on: October 27, 2016, 12:34:46 pm »
awesome, thnx.  The CP is a little questionable but everything else is tits
rablack97
« Reply #15 on: October 27, 2016, 02:10:28 pm »
One of my pet peaves is to have someone with woodworking skills such as yourself, skimp on the control panel by tossing premade fightsticks in a scratch build.
why didnt you fabricate the cp and put the controls inside of that, plopping two fight sticks reminds me of the folks that put tanksticks in mamecabs and thought that was ok.
You were headed down the path of work of art and then went into the I rigged this up look.
 :banghead:
atxscarface
« Reply #16 on: October 27, 2016, 02:39:39 pm »
I designed the CP in this fashion because I had already built the sticks myself.
http://forums.shoryuken.com/discussion/comment/10725418/#Comment_10725418
My setup is mobile, hence the PC is not built into the cabinet itself, it has its own ITX casing and I can easily take the PC and the sticks with me to the living room or hook it up to my projector for outside events we have sometimes. Even though I built this cab I dont want my gaming experience confined to it. And I don't want to have to purchase 4 Brook PCB's when 2 will do (Those things aren't cheap). This cabinet is meant to be a shell of sorts for not only the PC but for consoles as well.
rablack97
« Reply #17 on: October 27, 2016, 03:17:35 pm »
So you built this for your fight sticks?
 :cry:
Are you running xboxone, thats the only reason you would need the 90.00 Brooks board, you stated your using PC, why not use an IPAC 45.00 for 2 players.
Edit: You said PC and consoles, my mistake.
Still  :cry: for building around 2 fight sticks.
« Last Edit: October 27, 2016, 03:19:38 pm by rablack97 »
atxscarface
« Reply #18 on: October 27, 2016, 03:57:55 pm »
LOL, thanks for the support rablack. I appreciate your feedback, I do indeed plan on making some changes to the CP fastening but the concept stays. It fits my needs!  :cheers:
« Reply #19 on: October 27, 2016, 04:24:41 pm »
Props to Rablack97 for keeping it real, and props to atxscarface for taking it like a man and politely telling Rablack97 to ---fudgesicle--- off. Both sides showing how it should be done.
fablog
  • Last login:September 03, 2026, 09:38:02 pm
« Reply #20 on: October 27, 2016, 06:27:05 pm »
Very good job @atxscarface. I like a lot your CPO, are you OK to share it?  Anyways, congrats ;)
Envoyé de mon Nexus 5 en utilisant Tapatalk
menace
« Reply #21 on: October 27, 2016, 08:29:47 pm »
If you have a 2x4 under the MDF--run some bolts through the hinges with washers on either side--much less chance of a pull out with a bolted connection versus wood screws--it still makes me nervous with it hanging out like that but if you are against undermount brackets, that might fill the need...
Just make sure that the 2x4 connects beyond the top plate (the piece the hinges screw into)--or else it'll likely just pop the whole top plate off.
rablack97
« Reply #22 on: October 28, 2016, 12:34:42 am »
its all tough love, just trying to help my man out here.......
Still hatin on them sticks though  :cheers:
atxscarface
« Reply #23 on: October 28, 2016, 07:57:17 am »
Its all good man, hatas gonna hate! I knew not everyone had my type of taste when I posted this and Im sure you're not the last rablack, but again its all good when you can see past the cynical talk and take the criticism. Most of the time you guys mention or suggest improvements I would have never thought of. In this situation though youre asking me to change the entire concept of the CP which I don't have the time nor the funds to do so. So if the changes are minimal and I think it will help, definitely Ill take it into consideration. Anything else I just ignore (the beauty of forum talk!)
Ive seen some of your work rablack and its really good, very professional. However I don't have a CNC machine.  :dunno
rablack97
« Reply #24 on: October 28, 2016, 09:23:55 am »
Agreed, man if you know me on the forum, i just like to to give folks a hard time, at the end of the day i just want to folks to build great things, which you are (cough were (sticks) sorry.
I like your design, and understand your reasoning.
I would definately go with a heavier gauge piano hinge though man.  You have way too much overhang to support those 3 hinges already in place.  Get one of these and paint it black.
atxscarface
« Reply #25 on: October 28, 2016, 10:05:01 am »
Yeaah man! I was going to go for one of those and mount it on the underside of the CP routing a recess to fit that piano hinge flush against the bottom and use the hasp latches on the side to take some of the weight off. Please understand this project is not finished, I simply just couldnt wait to get it into the house and play on it a bit to get the feel and ensure I got the scale right. I did kind of rush the CP a bit but the concept is there, with your advice I have a better understanding how to get it more secure for the long run and with the underside mounting of the hinge it will look cleaner not seeing the hinges on the backside.
Overall though the CP is one piece, a major piece, but still one piece of the project that can always be modified and built on later if I feel the need. (Was thinking of fabricating a metal bracket with a rising motor for automated standup or sit down positioning) This project is for me and really just to see if I can do it, I have no intentions of selling this, until maybe rablack lets me borrow his CNC machine!!  ;D Anyways it will be a bit before the next update, the kids and wife are starting to get jealous of me spending so much time in the garage!
atxscarface
« Reply #26 on: October 28, 2016, 10:10:35 am »
This is a work of art and indeed a bit of inspiration came from here:
http://forums.shoryuken.com/discussion/103214/b15sdm-designs-vewlix-custom-arcade-cabinet-with-work-log
Thanks B15 for the door design, kind of copied that one.
atxscarface
« Reply #27 on: November 16, 2016, 03:55:15 pm »
LOL, decided to redo the control panel after all. I recycled the bottom to not waste too much.
atxscarface
« Reply #28 on: November 16, 2016, 04:04:42 pm »
Where we are at now. Just finished recutting and chamfer back panels (Previous ones were made out of scrap and did not quite reach)
Everything is in pieces for final light sanding and prep for paint.
« Last Edit: November 16, 2016, 04:07:29 pm by atxscarface »
atxscarface
« Reply #29 on: November 16, 2016, 04:16:23 pm »
Platform for control panel is bolted down underneath with 2x4
Im pretty happy with the USB and cable runthrough, no cables are shown unless you lift the control panel.
SpaceHedgehog
  • Last login:March 14, 2026, 10:40:09 am
  • Almost done ...
« Reply #30 on: November 16, 2016, 04:35:46 pm »
Looks very nice. I reckon you could trim down the supporting shelf for the CP a little so it loses the angles. Great job though.
Click a pic for a video tour
atxscarface
« Reply #31 on: November 16, 2016, 04:42:15 pm »
I did, I just didnt get a chance to take updated pics. I trimmed down the platform ends to sit flush with the bottom angle of the chamfer around the CP sides.
SpaceHedgehog
  • Almost done ...
« Reply #32 on: November 16, 2016, 04:53:30 pm »
Excellent. Looking forward to seeing this finished and up and running. What colour scheme /artwork are you going for?
atxscarface
« Reply #33 on: November 17, 2016, 07:18:11 am »
I was originally going for black and red, but I am honestly tired of that color scheme. I need it to match my office since that is where the cabinet is going to reside. Colors are Dark Gray (Black) with a lighter gray and white, my only thing is one set of buttons are red so I am debating just to throw those in there for now, or wait to purchase a new set of white buttons since gray seems to be hard to find or have in stock.
atxscarface
« Reply #34 on: November 22, 2016, 05:17:53 pm »
Need some help deciding:
1) Full Logos with Image
2) No Logos with Image
3) Full Logos No Image
4) Vewlix Logo Only No Image
5) No Logos No Image
Titchgamer
« Reply #35 on: November 22, 2016, 05:42:31 pm »
Man I love that!
Personally I would go number 2 out of the ones you posted.
But if you can get the HORI logo to match the other 2 would prob look ok.
It just looks totally out of place.
n3wt0n
« Reply #36 on: November 22, 2016, 05:56:53 pm »
My opinion, no Hori, No Chun Li, Maybe A Taito, I'm okay with Vewlix. Otherwise, looking good.
atxscarface
« Reply #37 on: November 22, 2016, 07:51:12 pm »
6th Option per @n3wt0n:
No Hori, No Chunli, Resized Taito logo
7th Option:
Resized Chunli image
I really like the image but I dont want to overdo the minimal style known of the Vewlix cabs so I toned down the opacity to blend in with the steel background, but it really looked nice over the stripes.
Image Credit:
http://sangjelata.deviantart.com/art/Chun-Li-Street-Fighter-vector-line-art-362610098
« Last Edit: November 22, 2016, 08:06:21 pm by atxscarface »
Titchgamer
« Reply #38 on: November 23, 2016, 04:08:00 am »
I think she fitted better on the right.
atxscarface
« Reply #39 on: November 23, 2016, 04:39:25 am »
8 ) My personal fav
