Author Topic: Raspberry pi 3 rainbow screen  (Read 8903 times)
hypergaming
  • Last login:May 04, 2022, 09:51:07 pm
« on: October 09, 2016, 01:18:05 pm »
Hi everyone,
I recently installed an image file in a new Raspberry pi 3, with a bunch of emulators including MAME, when I turn it on, I get a rainbow screen and Emulation station never starts.
I know is not the pi because I tried another SD card, and it loads Emulation Station. I want to use my original SD card because is where I have all my games and artwork I set up originally. here is an image attach of what I see on my screen.
is there any way I can fix this rainbow screen issue and load Emulation station as before?
Thank you  :notworthy:
hypergaming
Re: Raspberry pi 3 rainbow screen
« Reply #1 on: October 09, 2016, 01:53:29 pm »
Anyone?????
  • Last login:Yesterday at 12:32:32 pm
« Reply #2 on: October 09, 2016, 02:50:13 pm »
You literally waited four minutes to post your followup??
Just set up a new card and move the files over.
hypergaming
« Reply #3 on: October 09, 2016, 04:00:59 pm »
from 1:18pm to 1:53pm is not 4 minutes, is way more :)  but I totally understand is not a long time, I was just frustrated trying to get this thing done.
I did try burning the image on a new SD card, same image, but I et the same issue. I think it has to do with the version of Retropie, not sure.
thanks again
ed12
« Reply #4 on: October 09, 2016, 04:24:16 pm »
well it is not really getting to "boot", so yes look at the rev of the build
ed
elvis
  • Last login:January 13, 2025, 08:48:40 am
  • penguin poker
    • StickFreaks
« Reply #5 on: October 09, 2016, 09:56:25 pm »
Either
1) The image you've used is bad
2) The way you imaged the card was wrong (incomplete?)
3) The SD card itself is bad
Work you way through the troubleshooting of each.  (Retry writing the image, make sure it completes full and all writing has stopped before you remove the card, and failing that try a new card).
nexusmtz
« Reply #6 on: October 09, 2016, 10:57:45 pm »
I thought the rainbow could be a power problem. Does the image overclock the cpu, and have you tried a different supply?
You said you tried another sd card, but it's not clear if that was the exact same image.
Slippyblade
« Reply #7 on: October 10, 2016, 12:28:53 am »
A quick Google says your power supply is probably not putting out enough juice.  Try a better supply and cord.
hypergaming
« Reply #8 on: October 10, 2016, 12:43:23 am »
Thanks everyone,
It seemed it was an old version of retropie that wasn't compatible with rpi 3, I used retropie 3.8 and it worked.
 ;D  thanks again.
nitrogen_widget
« Reply #9 on: October 12, 2016, 11:21:29 am »
Thanks everyone,
 ;D  thanks again.
sudo apt-get update
sudo apt-get upgrade
while the card is in your old RPI will make the install on the SD card work on the RPI3
General_Faliure
  • Last login:March 01, 2022, 07:30:40 am
    • My Arcade Cab
« Reply #10 on: December 01, 2016, 07:09:14 am »
the rainbow screen is usually because of the power supply being not strong enough.
For a pi 3 you need a good power supply of at least 2 Amp, preferably 2.5.
My Arcade cab: https://goo.gl/photos/yE1KACHryQjCaaCj7
Core2 duo8400 @3.6 Ghz, 4Gb of mem, Geforce 9500.
Linux Mint 17.3 XFCE, Mame, Mess, Daphne FS-Uae, Mednafen and some more.
Mah!cade
mahuti
« Reply #11 on: December 04, 2016, 02:57:59 am »
I've also had lockup issues (probably due to power supply issues) when adding artwork overlay files. Weird. Similar to the problem you mention.
nitrogen_widget
« Reply #12 on: December 07, 2016, 10:46:22 am »
also may need to do:
sudo apt-get dist-upgrade while in rpi2 to get the card to run in rpi3.
Blanka
« Reply #13 on: December 31, 2016, 09:32:56 am »
Just disable it. It has nothing to do with power issues, it is just a boot logo. You can at the same time disable smooth OpenGL scaling. If you want blocky pixels, it will interfere. If you disable smooth scaling, you will see the rainbow image is just 4 pixels, like the Windows Logo in 4 colours.
Code: [Select]
sudo nano /boot/config.txt
comment:
# dtparam=audio=on
add:
disable_splash=1
disable_audio_dither=1
scaling_kernel=8
sudo nano /boot/cmdline.txt
dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty3 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet loglevel=3 consoleblank=0 vt.global_cursor_default=0 logo.nologo
sudo nano /etc/modules
comment out both snd-bcm2835 to #snd-bcm2835
sudo nano /lib/modprobe.d/aliases.conf
comment out to prevent conflict getting sound device index number
# options snd-usb-audio index=-2
The other stuff deals with the USB audio interface (you will need that too, see other topic!)
« Last Edit: December 31, 2016, 09:36:22 am by Blanka »
