Author Topic: How to exit this front-end (?) and USB not working/installing (?)  (Read 2620 times)
glideriock
  • Last login:September 30, 2016, 07:20:38 pm
« on: September 30, 2016, 02:24:26 am »
Hi, im new to this forums aswell to the Arcade machine scene, so sorry for the "noobness" !
so i wanna get some new games and change the front end, see what specs i have, etc. but i have no idea how to exit this front-end, im sure i need a keyboard, but the problem is,i only have a USB one, and when i connected it to any of the two USB ports the machine has, the keyboard doesn't work (no light on the num pad, caps lock,etc).
so the questions are: how do i exit this front end and i HAVE to use a ps2 keyboard ?
- Front end
- USB ports (with keyboard already in)
- The sticks and switches thingy
- Ps2 ports
Thanks a lot and sorry if a just murdered english language !
Titchgamer
Re: How to exit this front-end (?) and USB not working/installing (?)
« Reply #1 on: September 30, 2016, 04:52:59 am »
Do you know which front end that is?
glideriock
« Reply #2 on: September 30, 2016, 04:56:58 am »
Nope, thats  one problem i guess, i bought the arcade from some old dude that had no idea what to do with it.
its a common front end (if it is one) here in mexico, or atleast all the arcades look almost the same
Titchgamer
« Reply #3 on: September 30, 2016, 05:01:04 am »
Its just it looks like a DOS based front end so is it actually booting into windows?
glideriock
« Reply #4 on: September 30, 2016, 05:08:09 am »
well, when it startups, on the crt it displays only a lot of lines (like glitch art) and then the list of games, nothing windows-like
Titchgamer
« Reply #5 on: September 30, 2016, 11:37:41 am »
I suspect its run through DOS but hopefully someone else will be able to recognise it and help you.
But it maybe worth while using a PS2 keyboard to try.
