Author Topic: Input Lag/sync/scanlines running GroovyMame on a PC CRT monitor  (Read 3289 times)
snappleman
  • Last login:April 13, 2026, 11:38:49 pm
Hi everyone, I asked this question on another forum and got some nice info which directed me here. This place is amazing and I spent the last few days reading as much as I could but it's just so much to take in (and I'm not very technical...) so I'm a bit overwhelmed with the info.
Basically what I want to do is use an old PC VGA CRT monitor (Dell D1728D-LS SVGA monitor) for GroovyMame. I have an ATI HD2400 and HD5450 lying around that I can install CRT_emudriver on, but I have a few questions about what's possible with this setup:
1) Can I get a VGA CRT to sync at 15khz? Is this model dependent or simply impossible for these monitors?
2) Can I expect improved input response over an LCD when using a VGA CRT at 31khz + vsync?
3) Is it possible to get low/native Mame resolutions at 31khz (if the monitor can't sync to 15khz)?
I remember being into (buggy) emulation back in the mid/late 90s with nesticle, MAME and NeoRage and playing side by side with my consoles and going to arcades, and I didn't notice any difference in the input lag, but I really don't want to go building a new rig and getting old hardware out of storage just to find out that I'll have similar issues to using an LCD.
Anyway, thanks to everyone here for creating/contributing to this great place, and extra thanks to anyone who offers me some advice :D!
SailorSat
  • Last login:Today at 05:58:15 am
    • For Amusement Only e.V.
Re: Input Lag/sync/scanlines running GroovyMame on a PC CRT monitor
« Reply #1 on: August 28, 2016, 03:45:38 am »
1. Most newer VGA monitors start syncing at about 27kHz, so no 15kHz.
2. I would think so.
3. doubling the framerate / drawing each frame twice will double the frequency - but you will have MASSIVE scan lines, as the VGA tube has a much finer dot pitch.
I do all that stuff even without a Joystick ;)
Soft-15kHz, cabMAME, For Amusement Only e.V.
snappleman
« Reply #2 on: August 28, 2016, 04:59:25 am »
Thanks for the reply!
When you say "newer" I assume you mean mid 90s and up, right? This one is from around 1995 so I assume 15khz is out. Honestly being able to sync at 15khz is much less important to me than having good control response and no screen tearing.
I started reading the forum backwards since I figured these questions were more common in 2003, and I did learn a good bit more. Having better response and better colors along with a 4:3 aspect ratio with no black bars around an LCD is probably going to be enough for me.
If the double frequency scanlines are too distracting I assume I can run the games at higher resolution and sync MAME's refresh rate to the monitor (disabling throttle) and then just using a shader for the scanlines? Or do I have that process wrong?
« Last Edit: August 28, 2016, 05:07:33 am by snappleman »
