Author Topic: Joystick driver shennadigans!  (Read 1368 times)
pj.maybe
  • Last login:October 22, 2018, 07:06:43 am
  • Somewhat hopeless
« on: July 30, 2016, 11:25:14 pm »
 :banghead:
Absolutely dead stuck with this problem, hoping some kind soul can help me.
Want to play some games which need a Windows Joystick, and want to control that joystick from my IPAC (two JPACs actually) board inside my cabinet.
The catch?   I have a 4 player cabinet so the IPAC functionality to emulate joysticks wont work (only does 1 per board).
Fine!   So I disable the IPAC joystick (with the new firmware), and run vJoy to create joysticks, which I can then control with keystrokes.
All of this SHOULD work, but I have a weird issue where despite IPAC not creating any joysticks, when I add a vJoy one, it has the JPAC name.... and (perhaps understandably) doesn't work.
Check out the two pics attached.   [they show the bizarre behavior].   Do you guys know anything I can try?   Or even an alternate approach?   This is driving me mad!
 :cry: :cry:  :timebomb:  :cry:
p.s:
Thought vJoy might be the problem so tried "Headsoft" vJoy (bizarrely unrelated), and had the same issue.
It pays to be obvious, especially if you have a reputation for subtlety. ~ Isaac Asimov
