Author Topic: C&C on these plans  (Read 1841 times)
FALSE
  • Last login:February 25, 2024, 08:13:59 pm
C&C on these plans
« on: July 17, 2016, 09:24:13 pm »
Found these plans for a side panel and I think I'll copy them exactly.
Planning on making it 22"-24" wide.
Using a large (40"?) led monitor turned vertically.
Anyone see any glaring issues with these plans?
otsep
  • Last login:September 28, 2025, 02:53:45 pm
  • I'm your huckleberry...
Re: C&C on these plans
« Reply #1 on: July 17, 2016, 10:20:11 pm »
Looks very similar to my first one. Good luck
Sent from my iPad using Tapatalk
Vids: Namco Rockin' Bowl-O-Rama
Pins: Aerosmith Pro, ST Premium Vault, Beatles Gold
Remember Wheaton's Law
Afterburner
  • Last login:July 27, 2016, 01:02:00 am
« Reply #2 on: July 19, 2016, 08:58:39 am »
I'll add that I had (actually still have) and LCD Top Gun II that I used for a while on my stand up cab.
It worked OK, but I had to stand back from the screen/IR LEDs about 4-5 feet, which was far less than ideal for a stand up cab with a 21" monitor.
If you are using a showcase style cab, or just run it off a large TV where you can stand back a ways, it works fine.
Some people modified the lens on the gun to one with a wider angle that helped some.
The Aimtraks are supposed to be better, allowing you to get 2-3ft back.  And the Aimtraks are probably much easier to get working since they appear as a regular mouse.  No drivers to fiddle with.
But if you are hoping to duplicate the experience of playing Duck Hunt or Hogan's Alley on a standup cab, you likely will be disappointed since you can't belly up to the CP and blast away.
  2-player upright dual trackball / dual 8-way rotary joysticks - built from scratch
