Author Topic: Raspberry pi how to map xinmo dual joystick with sega megadrive, nintendo, etc.?  (Read 4508 times)
hypergaming
  • Last login:May 04, 2022, 09:51:07 pm
Hi everyone,
I set up Retropie on my Raspberry pi 2 Model B, I have multiple emulators but the controllers only work with MAME, I can't play any of the other emulators because there is no function on any other joysticks or buttons. i did some research and there should be a " configs " folder, but it doesn't show in my installation.
Can anyone tell me how to map the xin mo dual joysticks controllers with Sega Megadrive, Nintendo and the other emulators?
Thanks.
ballboff
  • Last login:August 23, 2026, 04:53:50 pm
Assuming you're using retropie.  There should be an option in retropie setup menu to load up retroarch gui.  From within there I believe you can configure your controls from the input menu, that should configure all your emulators I think.  You can check the controls in /opt/retropie/configs/all/retroarch.cfg.  One time I configured mine I think I had to delete this retroarch.cfg file and start again.
hypergaming
Thanks for your help, yes, I'm using Retropie, I did configure the controllers but the weird thing is that i do not see any " configs " directory in the server when I tried accessing the pi using ftp, for what I understand, this folder gets generated after you st up your controls, but I do not see it, so for this reason, I cannot find the file " retroarch.cfg ".
can I create this directory manually and maybe paste someone's retroarch.cfg configuration into mine?
thanks.
ballboff
Try sudo find - name "retroarch.cfg" just to make sure...
Sent from my Fire Phone using Tapatalk
