Author Topic: Aim-Trak Guns losing assignment in Mame Menus after reboot.  (Read 3689 times)
wolfievtec
  • Last login:July 09, 2016, 08:26:29 am
I am new to these emulators, I am using 2 AIM-Trak Light Guns with a MAME emulator (Atomic Studio, Video-PAC)   I have set everything up following the directions and everything works great until I reboot the computer. Then my gun assignment is somehow reset and I have to go into each game and change the gun assignment.
Example: The guns are assigned Device 1 & Device 2 in the AIM-TRAK Utility. The games show gun 2 & 3. That’s ok and I can configure it but if I reboot the PC, in the guns are now 3 & 4. Then I have to go through each game and reconfigure each game to work with the new gun number.... Any thoughts? Thanks!
argonlefou
  • Last login:Today at 08:03:52 am
Re: Aim-Trak Guns losing assignment in Mame Menus after reboot.
« Reply #1 on: July 08, 2016, 09:54:39 am »
Yes that's normal (unfortunatelly !)
You have a software exactly for that : http://forum.arcadecontrols.com/index.php/topic,108767.0.html
And here a GUI for it : http://forum.arcadecontrols.com/index.php/topic,145636.0.html
dgrace
  • Last login:Yesterday at 12:40:26 am
« Reply #2 on: July 13, 2016, 02:17:45 am »
This is awesome.  I have the same problem.  It seems I always have to remap both aimtrak guns (player 1 and 2) every time I want to play light gun games in MAME in 2 player dual mode.  Does this program really work? Is there a tutorial on how to set it up? Is it pretty simple?  Thanks
argonlefou
« Reply #3 on: July 13, 2016, 03:58:30 am »
There is a 15mn full setup-guide-video on the 2nd link
Ginsonic
  • Last login:January 12, 2026, 06:48:01 am
  • Arcade enthusiast !
« Reply #4 on: July 13, 2016, 06:32:21 am »
It works great, but IMO it is not simple at all. Unfortunately it has a steep learning curve, but it pays off investing some time !
stigzler
    • Mago Arcade
« Reply #5 on: July 22, 2016, 05:15:37 pm »
You could always hand-configure the xml files yourself and see if that makes it simpler...
 :laugh2:
Only j'king! Glad it helped.
Sorn
  • Last login:July 09, 2018, 08:56:19 pm
« Reply #6 on: July 26, 2016, 01:20:37 pm »
I believe the reason this happens is because the way windows assigns ID's to usb emulated devices is funky. So if you are unplugging and replugging any usb devices it can screw with the USB id's and then mame freaks out and defaults the list or blanks it.
What i do to overcome this is to never, ever unplug anything, and then once I setup my guns/controllers I make the default.cfg read-only. You can do the same to the individual .cfg files that are generated for the games, if you have specific this-game-only controller configs. So for example I play point blank the most, so I can right click ptblank.cfg and make it read only and then nothing can change that controller config. You'll have to uncheck read only in properties to get mame to be able to edit it again though if your ID's change and you need to remap!
I've used the program above, but frankly im not sure if it works or not. Something to do with directinput vs rawinput (i think?), so it depends on the device type whether or not it is able to actually map them correctly on boot.
