Author Topic: Show Marquee while playing game  (Read 5219 times)
CobraChris
  • Last login:February 08, 2017, 03:56:15 pm
« on: July 07, 2016, 05:34:28 pm »
Ive searched with no luck... Looking to see if there is a way that I can display current games Marquee on the same screen game is being played?Im using a large vertical widescreen monitor and would like to use top of screen to act as a Marquee.
I figured I can by modifying the bezel artwork and Layout but that would take forever.
markc74
  • Last login:Today at 05:55:42 am
  • Flipping out
Re: Show Marquee while playing game
« Reply #1 on: July 07, 2016, 05:38:31 pm »
You mean like the attached image?
You can do it with layout files but you'll need to create one for each game. Let me know if you need a default one to get you started.
CobraChris
« Reply #2 on: July 07, 2016, 05:41:05 pm »
Yes that is what I was thinking! ,I knew its been done before just couldn't find out how
Could you show me a sample to the Layout file?  Ive never messed with any of them.
JDFan
« Reply #3 on: July 07, 2016, 05:42:16 pm »
See markc74's Blip build thread -- He uses a separate monitor for the active marquee but same concept and the thread should have some helpful info -- http://forum.arcadecontrols.com/index.php/topic,137295.80.html
Reply #97 has several pics of it in action
LOL -- sniped by markc74 while typing and finding the thread !!
CobraChris
« Reply #4 on: July 07, 2016, 05:57:02 pm »
Ive tried the LCD marquee and failed....FML
Same idea just on the same screen.
markc74
  • Flipping out
« Reply #5 on: July 07, 2016, 06:00:05 pm »
 ;D - It was only because I tried this idea out myself last week. I was thinking of doing a vert widescreen build myself if I ever get the time but I've got an asteroids cabaret and virtual pin to do first...
Unzip the attached file into your artwork folder in mame and run the game. All being well it should show the marquee and bezel. You'll have to tweak the dimensions in the layout file if you want to use it in other games. Laythe has already done a load of this work on his Mimic build which is defo worth a look:
http://forum.arcadecontrols.com/index.php/topic,149109.msg1555074.html#msg1555074
CobraChris
« Reply #6 on: July 07, 2016, 06:58:52 pm »
You are a life saver!
But still a noob... Got marquee to work, needs adjusting but how do I make the Game fill in the rest of screen?
nexusmtz
« Reply #7 on: July 08, 2016, 04:08:08 am »
...Got marquee to work, needs adjusting but how do I make the Game fill in the rest of screen?
This sounds like:
Can you give mame a specific portion of the screen, and a marquee on the top?
I explained the math there.
