Author Topic: Megatouch Sapphire 2 Touchscreen woes  (Read 4280 times)
geforcefly
  • Last login:July 10, 2017, 04:48:57 pm
« on: June 23, 2016, 01:54:12 am »
All of a sudden my touchscreen on my Maxx doesn't want to work properly.  Mine is hacked and has none of the normal boards in it.  The touchscreen input is broken in megatouch proper but when I was trying to get any response going with the keyboard it turned out that Shift-ESC exits me to bash.  I can use the touchscreen to highlight areas on the screen and that works perfectly.  Needless to say I need to reset the microtouch driver... I wonder how I can do that...  Let me know!
Machines: GT! Fore Complete / SSB 2007 (manually switched), SF Rush: The Rock (dedicated), hacked Street Fighter II / 60 in 1 (manually switched) (started as a Space Duel and converted a gazillion times), Megatouch Maxx Sapphire 2
mahkeymike
  • Last login:July 24, 2025, 05:09:51 pm
Re: Megatouch Sapphire 2 Touchscreen woes
« Reply #1 on: June 23, 2016, 07:35:49 am »
I know with Force systems dip switch #6 on the IO board will reload the touchscreen drivers. I am not sure with MAXX and i do recall helping you get into operator setup without a IO board so obviously you dont have an IO board. There might be another way to trigger that driver reload without the IO board but unfortunately I dont have any original MAXX hardware to test with.
Maybe someone else can shed some light on other ways to reload the drivers. I am not sure what would happen if you manually go in and delete the touchscreen driver modules. Since your system is hacked, a original disc reinstall would render your machine useless.
orizzle
  • Last login:September 21, 2020, 07:20:41 pm
« Reply #2 on: June 23, 2016, 09:36:27 pm »
Buy an ioboard. I'll sell you a crown key.
geforcefly
« Reply #3 on: June 25, 2016, 09:55:07 am »
I originally got the machine for free with a faulty Unicorn socket 7 motherboard (it had everything else required including the IO board for it), and it turned out a standard 810 board booted the machine.  What I ended up doing was copying opsetup.so to idle.so (after renaming the original) so it would go into service mode and I was able to recalibrate the touchscreen (which when it was malfunctioning, kind of acted like it was inverted on the Y axis).
mahkeymike
« Reply #4 on: June 25, 2016, 11:32:34 pm »
I think you should get a classic force ioboard like this one.
http://www.ebay.com/itm/MERIT-FORCE-I-O-BOARD-FITS-RADION-CLASIC-VIBE-ELITE-MEGATOUCH-TOUCHSCREEN/301975183752?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20131003132420%26meid%3Dc133db93480b458dba812a46b0c4ea79%26pid%3D100005%26rk%3D1%26rkt%3D6%26sd%3D200909370106
Dont pay that though. I see them go for $15 every so often on ebay.
Its USB and there is functions in your version software that support it. I dont have that IOboard to test but im 75% sure it will interact and reload the touchscreen drivers.
