June 13, 2026, 10:20:27 am
QuoteMini-PacMini - Pac Wiring GuideBy Mayhem40 Pin Connector x = polarizing Key________________________________________________________________-- 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ---- x 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 --________________________________________________________________40 Pin Connector numbered - X = polarizing Key_________________________________________________________________-- 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 ---- X 3 5 7 9 11 13 15 17 19 21 23 25 27 29 31 33 35 37 39 --_________________________________________________________________Connector Pin 40, Ground 1 (Optical Only)[Not used] Pin 39Trackball X TX1 Pin 38Trackball X Ground 1 (Power harness)Trackball X +5v 1 (Power harness)Trackball X TX2 Pin 37Trackball Y TY1 Pin 36Trackball Y Ground 2 (Power harness)Trackball Y +5v 2 (Power harness)Trackball Y TY2 Pin 35Spinner data Pin 34Spinner data Pin 33Spinner Ground 3 (Power harness)Spinner +5v 3 (Power harness)Top Colour Group Mouse Left Grey Pin 32Mouse Right Purple Pin 31Coin-P1 Black Pin 30Coin-P2 White Pin 29Start-P1 Red Pin 28Start-P2 Brown Pin 27P1 Left Yellow Pin 26P1 Right Orange Pin 25P1 Up Blue Pin 24P1 Down Green Pin 23P1 Switch 1 Grey Pin 22P1 Switch 2 Purple Pin 21P1 Switch 3 Black Pin 20P1 Switch 4 White Pin 19P1 Switch 5 Red Pin 18P1 Switch 6 Brown Pin 17P2 Left Yellow Pin 16P2 Right Orange Pin 15P2 Up Blue Pin 14P2 Down Green Pin 13P2 Switch 1 Grey Pin 12P2 Switch 2 Purple Pin 11P2 Switch 3 Black Pin 10P2 Switch 4 White Pin 9P2 Switch 5 Red Pin 8P2 Switch 6 Brown Pin 7P1 Switch 7 Yellow Pin 6P1 Switch 8 Orange Pin 5P2 Switch 7 Blue Pin 4P2 Switch 8 Green Pin 3Ground Grey Pin 2Polarizing “Key” Pin (not used) Pin 110 Pin Connector x = polarizing Key___________________-- 0 0 0 0 0 ---- x 0 0 0 0 --___________________10 Pin Connector numbered - X = polarizing Key____________________-- 2 4 6 8 10 ---- x 3 5 7 9 --____________________X = polarizing Key2 = +5 Volts (3)3 =4 =5 = Ground (3)6 = Ground (2)7 = +5 Volts (2)8 = +5 Volts (1)9 =10 =
