Author Topic: options for 4 way / 8 way joystick  (Read 1322 times)
GroovyTuesdaY
  • Last login:June 07, 2005, 03:22:18 am
  • "Follow the white rabbit! ....KNOCK KNOCK NEO...."
« on: January 17, 2004, 01:09:10 am »
I need to know what is a good 4 way joystick option,but still be able to  switch to back to 8 way?    I am using happ supers right now, so i think i would like something with the same kind of feel as that stick, but the ability to switch back of forth with relative ease.
Any suggestions or experiences ?   Maybe i just need to stick with a dedicated 4 way,but i was hoping to keep the stick clutter on my panel to a minimum lol
thanks
groovy~
In the mighty words of the BEE GEES im-
"STAYIN' ALIVE, STAYIN' ALIVE!"
hehehe
TalkingOctopus
    • My Arcade
Re:options for 4 way / 8 way joystick
« Reply #1 on: January 17, 2004, 12:09:51 pm »
Take a look at the T-stick plus on this page:
http://www.ultimarc.com/controls.html
It may be what you are looking for.
spidermonkey
  • Bombjack junkie
« Reply #2 on: January 18, 2004, 09:43:23 am »
"Sinistar has bad breath"
dmhayden
  • Last login:January 18, 2004, 11:26:57 am
« Reply #3 on: January 18, 2004, 12:19:08 pm »
I have a Happ super and two T-Stick Plus's.  The T-Stick plus's can be switched from 4-way to 80-way by pulling up on the shaft and rotating it 90 degrees.
The T-stick's use a tighter spring and they have less throw than the Happ, but I think I actually prefer that.  They're certainly convenient.
wpcmame
  • Last login:February 18, 2024, 01:27:00 pm
« Reply #4 on: January 18, 2004, 12:54:14 pm »
Also got 2 T-Stick plus and I am happy with them. Only problem is that it is tricky to mount the cables so that they don't interfere with the 4/8 switching bracket. The T-stick plus will use another mechanism in the future that shouldn't have this problem.
The travel on the stick is very short and it took me some time to get used to. Still think it is a little to easy to accidently hit a diagonal in 8-way mode.
crashwg
« Reply #5 on: January 18, 2004, 11:42:24 pm »
You also may want to check out oscarcontrols' joystick restrictors.  In case you don't know what they are, they use your existing joystick and restrict (hence the name) where the joystick can go.
http://www.oscarcontrols.com/index_joystick.htm
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
