Author Topic: New Mame Resolution INIs generator tool  (Read 4405 times)
Pitou
  • Last login:March 10, 2026, 04:16:11 pm
« on: June 08, 2016, 04:27:49 pm »
Hello,
Here is my attempt to provide a little utility to generate resolution INIs for setups with an arcade monitor.
The tool is based on a map table (CSV file) to generate the resolution INIs.
You can also add extra parameters if needed.
It's coded in VB.NET and requires .NET framework 4.6.1
Play with with it and tell me if it worth it.
Feel free to report any bug.
Also, don't hesitate if you have any idea for improvement.
I will try to do my best. :)
Thank you.
Pitou!
Changelog:
June 22nd 2016:
Version 0.8:
- Added vector games support.
- Added list of games with resolution generator.
- Some games have 2 display entries for multiple screens. The tool will generate based on the first display statement only.
- Bugfixes.
June 15th 2016:
Version 0.7:
- Improved resolution detection
- Vertical monitor supported
- Separated stretch and rotation in different text fields
- Generating different filenames for the resolutions CSV file
- Bugfixes
June 11th 2016:
Version 0.6:
- Improved resolution detection.
- Made some other parameters user configurable
- Next is games on vertical monitor improvement.
June 11th 2016:
Version 0.5:
- Added vertical games on horizontal monitor
June 10th 2016:
Version 0.4:
June 9th 2016:
Version 0.3:
- Bugfix, last resolution was not written
- Can now make some decisions on resolution to pick. So far 3 conditions have been implemented.
  1- Resolutions lower than the lowest resolution monitor setting will be set at the lowest monitor resolution setting
  2- Exact match
  3- Resolutions higher than the maximum one set, will be set at the maximum resolution provided
June 9th 2016:
- Vertical max resolution now configurable
- Experimental "Extract detection" button. So far, it only validates resolution lower than 240x240 and set it at 240x240
June 8th 2016
Version 0.1:
- First Draft
« Last Edit: June 23, 2016, 08:39:06 am by Pitou »
Pitou
Re: New Mame Resolution INIs generator tool
« Reply #1 on: June 09, 2016, 04:12:25 pm »
I made some progress but would need some advice on how to treat some resolutions.
- Should I base the condition on the vertical res et pick the closest horizontal?
- Vice versa?
- What about some res like 1024x256? Better pick 256 and find a lower horizontal number?
Any help or suggestion is appreciated.
Thank you.
Pitou!
Pitou
« Reply #2 on: June 09, 2016, 11:29:53 pm »
ok I made some assumptions to pick up resolutions.
Still to do, pick up the right resolution for vertical games on horizontal monitor. Will add a checkbox to choose a horizontal monitor or not.
Pitou!
Pitou
« Reply #3 on: June 22, 2016, 09:20:21 pm »
New features and improvements, take a look!
Pitou!
