Author Topic: HLSL Blank Screen - Fresh DX9/Mame Install  (Read 3047 times)
NinjaZero
  • Last login:April 23, 2024, 04:19:35 pm
    • RetroGameInStyle
« on: June 04, 2016, 11:09:38 pm »
I have finished building my cab and have everything just about working great.  I am trying to get HLSL (Love HLSL Vector Glow) working and did the following.
Installed DX9 runtimes (including updates)
Installed Mame 0.174 "-cc"
installed Shadow-mask.png and others in Artwork folder (made sure everything is in right place)
Installed *.fx files in HLSL folder
I get no errors when I run the game via verbose mode, except that I get a greyish box roughly the size of the game screen.  I can hear the games running and if I hit tab I can see the menu but I do not see the game running behind it.  Only what appears to be a blank screen.
I deleted my ini and re-created it with mame -cc then I ran mame with only the -hlsl_enable flag but I get the same thing.  Here is the output of my -verbose output with the supplied mami.ini file.  If anyone has anything I can try please let me know.
##UPDATE##
HLSL Works in 0.169 - Tried to downgrade and noticed that something changed in 0.170 because after that it no longer works on my system.  Still I would appreciate any advice.
##OUTPUT## 0.174
D:\Arcade\emulators\MAME>mame ghouls -verbose
Video: Monitor 00000000088d7708 = "\\.\DISPLAY1" (primary)
Direct3D: Using Direct3D 9
Physical width 1920, height 1080
Direct3D: Configuring adapter #0 = NVIDIA GeForce GT 730
Direct3D: Selecting video mode...
   640x 480@ 60Hz -> 735.842896
   720x 480@ 60Hz -> 735.579895
  1024x 768@ 60Hz -> 734.737427
  1280x 720@ 60Hz -> 734.611450
  1920x1080@ 60Hz -> 734.311462
  1440x 900@ 60Hz -> 734.470581
  1400x1050@ 60Hz -> 734.436157
Direct3D: Mode selected =  640x 480@ 60Hz
Direct3D: Using dynamic textures
Direct3D: YUV format = RGB
Direct3D: Max texture size = 16384x16384
Direct3D: Device created at 640x480
RawInput: APIs detected
DirectSound: Primary buffer: 48000 Hz, 16 bits, 2 channels
Input: Adding Kbd #0: HID Keyboard Device
Input: Adding Kbd #1: HID Keyboard Device
Input: Adding Mouse #0: HID-compliant mouse
Input: Adding Gun #0: Win32 Gun 1
Input: Adding Joy #0: Xin-Mo Dual Arcade
Input: Adding Joy #1: Xin-Mo Dual Arcade
Region ':maincpu' created
unzip: opened archive file D:\Arcade\Mame\roms\ghouls.zip
unzip: found D:\Arcade\Mame\roms\ghouls.zip ECD
unzip: D:\Arcade\Mame\roms\ghouls.zip has no ZIP64 ECD locator
unzip: read D:\Arcade\Mame\roms\ghouls.zip central directory
unzip: closing archive file D:\Arcade\Mame\roms\ghouls.zip and sending to cache
unzip: found D:\Arcade\Mame\roms\ghouls.zip in cache
Region ':gfx' created
Region ':audiocpu' created
Region ':oki' created
Region ':aboardplds' created
Region ':bboardplds' created
Starting Ghouls'n Ghosts (World) ':'
Optional memory region 'stars' not found
Optional shared pointer 'decrypted_opcodes' not found
Optional device 'msm2' not found
Optional device 'msm1' not found
Optional device 'm48t35' not found
Optional shared pointer 'output' not found
Optional shared pointer 'objram2' not found
Optional shared pointer 'objram1' not found
Optional shared pointer 'qsound_ram2' not found
Optional shared pointer 'qsound_ram1' not found
  (missing dependencies; rescheduling)
Starting M68000 ':maincpu'
Starting Z80 ':audiocpu'
Starting Video Screen ':screen'
Starting gfxdecode ':gfxdecode'
Starting palette ':palette'
Starting Speaker ':mono'
Starting YM2151 ':2151'
Starting OKI6295 ':oki'
get_texture_target() - invalid size
register_texture() - 384, 448
register_texture() - 5, 16
register_texture() - 3, 16
register_texture() - 4, 16
register_texture() - 1, 16
Average speed: 100.00% (11 seconds)
Sound: buffer overflows=2 underflows=0
« Last Edit: June 05, 2016, 02:21:58 am by NinjaZero »
Groovymame LCD HLSL Settings
Check out the link on my profile (to the left)
