Author Topic: How to add custom resolution for other EMU (HELP)  (Read 4579 times)
roccias
  • Last login:August 18, 2023, 08:44:09 am
« on: May 26, 2016, 09:12:42 am »
Hi guys, I need an Help. I installed groovymame 0171 and thanks the help of different users of this forum, I configured it. How do you know, groovy mame with VM Maker install the super resolutions. The problem is when I want to use other emulators (( kega per megadrive - Mega cd.... Magic Engine ..... Snes9x .... Nes .... .SSF.....Epsx.... Model 2....Demul) and having a pixel perfect resolution. This emulators using different resolution; 256 x 224 @ 59.826098  - 336 x 224 @ 59.826098 and so on. Super resolution works great with groovymame but with others emulator I need to add manually this resolutions. My question is: There is a method to add this resolutions without enter in conflict with Super resolution ? I want when I run groovymame go to choose Super resolution but When I use others emulatori go to choose the resolutions add manually. Help me please.... Thank you
theelf
  • Last login:June 12, 2016, 06:33:54 pm
Re: How to add custom resolution for other EMU (HELP)
« Reply #1 on: May 26, 2016, 09:45:59 am »
maybe you can add custom resolution like  2536x224 for this emulators, and do a simple stretch in the emulator
1920x240 for Fusion
1920x242 for Magicengine
2536x224 for snes9x
Something like this
roccias
« Reply #2 on: May 26, 2016, 02:38:15 pm »
Thank you for the answer but I need something more simple  (I get  confusion with strange resolution ;D). I need to add this resolution because I want that when I run a megadrive game with Kega, I would like that choose for example 256 x 224  but when I run an arcade game groovy mame choose a super resolution .  I hope that it's possible. Thank you
theelf
« Reply #3 on: May 26, 2016, 06:32:23 pm »
I can think in nothing more easy that add a bunch of resolutions, and configure the emulators to use it (in fact... this is the only way to do)
For example, 99% megadrive games use 2 different resolutions,  in Kega,  320x240 and 256x240,  if  you use 1280x240 or 2560x240  or 3840x240...  all games will look perfect
roccias
« Reply #4 on: May 27, 2016, 07:45:29 am »
Thank you. I have to add this resolution
256 x 224 @ 59.826098 pcengine
336 x 224 @ 59.826098 pcengine
544 x 224 @ 59.826098 pcengine
256 x 242 @ 60.000000 pcengine
336 x 242 @ 60.000000 pcengine
544 x 242 @ 60.000000 pcengine
## Mega Drive - Genesis ##
256 x 224 @ 59.922738 megadrive
320 x 224 @ 59.922738 megadrive
256 x 224 @ 60.000000 megadrive
320 x 224 @ 60.000000 megadrive
## Super Famicom - SNES ##
256 x 224 @ 60.098475 superfam
512 x 225 @ 60.098475 superfam
256 x 240 @ 60.098475 superfam
256 x 239 @ 50.000000 superfam
512 x 478 @ 25.000000 superfam
512 x 448 @ 30.000000 superfam
## Sega Saturn ##
320 x 224 @ 59.185606 segasat
352 x 224 @ 59.185606 segasat
640 x 448 @ 30.000000 segasat
704 x 512 @ 30.000000 segasat
What resolution I have to write and I have to make it in the Ini file of every emu ?  Thank you
theelf
« Reply #5 on: May 27, 2016, 04:57:53 pm »
Hi, well, this is my opinion
If you use emulators like Kega, Mednafen, etc i dont think using exact refresh rate will make any difference
A 15khz CRT  TV have a "resolution" of  240 lines in NTSC and 288 in PAL
In my setup, i have  2536x240@60hz and 2536x288@50hz,  and adjust emulators to this resolutions. You can add 2536x480/2536x576 for high res
About saturn,  deppend emulator,  SSF sadly dont support low resolutions, only interlaced
