Author Topic: Mala 1.82 issue/possible bug with GUI\Info Window and cpwizard png images  (Read 5553 times)
dragon_sa
  • Last login:June 27, 2024, 07:59:29 am
I  am using mala 1.82, mame172 64bit on win7, I have a set of 158 roms with artwork etc.
I created all the control panels with CPwizard using a custom design matching the arcade machine layout and put the 158 png files i need in a directory called cp_images
I then set that to definable1 in mala.in
In the control panel I set GUI\Info window to have
    Controls - Type(image) - Image type(definable1) - Title(Controls)
    Snap - Type(snap)  -Image type(snap) - Title(Snap)
    Hi score...
    Cabinet..
    Marquee..
    Flyer...
When I press info button I assigned, sometimes the controls image is displayed and sometimes its not...
if i scroll thru the other menu items and come back to the controls image sometimes it will display sometimes it wont
All other image windows(snaps\cabinet\flyers\etc) display fine
The control images are not huge png files
If i set Controls to the second place in the menu order and snaps to the first place all the control images appear to display fine...issue now is the info button is primarily used to display the controls and I would prefer to have this first...
Hoping someone may be able to shed some light on this weird behavior/ possible bug
dragon_sa
just a further update, it only happens to the cpwizard images it also doesn't matter where i put them in the menu order now....
i have discovered that it happens the more times i call the control panel images up, after about 10 different control panels maybe less sometimes it stops showing them, or if i call the same control panel up several times...
im wondering if its some sort of memory or video issue...all images are only 200-230kb...all snaps, cabinets, flyers, control panel photos and marquess show flawlessly..
I cant just use the control panel photos as a lot of games they don't exist for.
