Author Topic: Screen curl K7191  (Read 1477 times)
Screen curl K7191
« on: April 25, 2016, 07:53:51 am »
you can see it here:
Recapped the monitor, and the picture got better and brighter but the curl is still there, I only seem to notice it with Strikers 1945 board. Should note, the previous owner went hacktopia on the chassis:
Anything else I should try before I throw this monitor at a kitten?
Here is KungFu Master running through a jamma adapter:
And american Horseshoes (upside down)
Should also note that when I put the strikers board in my CPS2 cab, there is no curl.
« Last Edit: April 25, 2016, 09:50:15 am by Malenko »
burn_654
  • Last login:April 29, 2025, 04:25:44 pm
Re: Screen curl K7191
« Reply #1 on: April 25, 2016, 01:47:46 pm »
Is the sync pot bad/in spec with what's expected? Maybe there could be a corroded section on the pot and that's the range that strikers needs. It looks like the sync can't lock on all the way to me. I'd check any work done on traces after the h,v sync pins too.
« Reply #2 on: April 26, 2016, 09:11:18 am »
from KLOV  (zenomorph=MK3Fan here)
Quote from: zenomorp;3340171
You just need to adjust your H.Hold.
Did this, and its almost gone, there is an ever so slight bend that I just cant seem to find a sweet spot for, but it is SIGNIFICANTLY better.
And not really noticeable during gameplay:
