Author Topic: Can't get batch file to unmount Saturn disk on exit  (Read 3905 times)
breathsavers
  • Last login:September 27, 2024, 03:14:01 pm
« on: April 15, 2016, 12:48:06 pm »
I made a thread for this in the Software forum but I'm beginning to think it's an MA problem. Basically, I have a working batch file that will unmount the disk in Alcohol 120 outside of MA (Daemon Tools won't install for some reason). I pointed MA to that .bat file as the Post-Launch application to run, but it just doesn't unmount the disk. After trying to use the .bat file and exiting MA, the batch file will no longer work outside MA either until I manually unmount the current disk from the Alcohol 120 program. Then it will unmount in windows explorer again. So strange. Any thoughts??
The Pre-Launch command loads the correct game fine.
Attached is the working batch file and screenshots of MA.
breathsavers
Re: Can't get batch file to unmount Saturn disk on exit
« Reply #1 on: April 17, 2016, 08:42:40 pm »
Anyone have any ideas?? I think something in MA is making the unmount script not work.
